If the controller has a good autodetect routine, it may get you close enough to either just work or to start off with anyway and tune from there.
Accurate specs for most of these motors don't exist. Usually have to be determined by the end-user prior to setup, depending on which specifics are required for the controller (vs which it can detect on it's own well enough).
Phase resistance you can get by running a known current thru the winding and measuring the voltage drop; ohm's law gives the resistance.
Kv (RPM per volt) you can measure by measuring motor RPM (phone apps, etc) at full throttle offground with the measured battery voltage at that moment it will be approximately that at the motor itself, close enough to use this number as a starting point.
Inductance you'd need something capable of measuring the very low inductance of the motor, and meters for that can cost as much as controllers (or more).
If there's a DIY way of measuring it, I haven't been able to find it or get anyone that knows to tell me how.
number of poles (or pole pairs) is the magnet number (or divided by two for pairs).
Also, this, in the other thread you're discussing this problem in:
https://endless-sphere.com/forums/viewtopic.php?f=30&t=100331&p=1735810#p1735810
