Hyena
Nice work mate, particularly the leather.
Did you get your throttle issue sorted ? I may have missed it but did you say what type of throttle it is ?
Standard hall type or magura ? You can specify in the kelly programming and if you've not programmed the right type that could be your problem. Also if it's a hall type and you got the wiring wrong there's a good chance you've killed the hall sensor in the throttle. I took out 2 brand new throttles years back when I first started amassing ebike gear and plugged them in to a different type of controller without checking the wiring order. If the loom you have isnt straight forward with the wiring colours (eg like bloody crystalyte controllers that use something like yellow brown and white for the throttle) then measure first with a multimeter. to find your + and - 5v
