Rix
100 TW
Aebrennan said:Here are some pics of the newly fitted primary drive chain conversion, 13-30T sprockets.
That came out great. Is the primary chain conversion kit something that Sur-Ron sells Or is it something you are doing?
Aebrennan said:You can find the manual for the Fastace forks on the www.aebikes.com.au website under downloads.
Do not attempt to add air pressure to the forks without reading the manual first, you may do a Hyena.
If you remove the key switch surround, you can unplug the brake sensor cables and prevent unwanted brake cut/safety when using the throttle. I have removed them completely on 2 of my bikes.
Out of the box the chains (Choho brand) are poorly lubed, a good clean a proper MX chain lube will get a quiter chain instantly.
Hope this helps a few new owners.
motomoto said:So I was not happy with the Fast Ace fork from the beginning. The RST Killa fork that came on the test bike was awesome with
zero maintenance. With the Fast Ace, the right side started weeping oil from the seal after the first easy ride. The factory sent
me a new one right away. After several weeks I noticed the forks were lower in their travel. I bought a Fox shock air pump
on amazon for $23 because I knew that when the connector is unscrewed the air leaks out and spoils your air pressure.
I recommend the pump to every Fast Ace owner. My fork keeps leaking air from the main chamber to the negative air chamber
and the fork gets lower and lower. To temporarily fix the lowering fork you let the air out of the top of the fork (negative spring)
so the fork pops up. Then you connect your Fox shock pump to the Schrader valve at the bottom front of the tube and pump it up
to 70 or so PSI. Make sure the fork is all the way extended. Unscrew the pump quickly as it leaks some air out as it is removed. I do the same thing with the negative air chamber from the top of the fork, but put in 40 or so PSI. Figure out what pressures work best for you.
Rix said:Aebrennan said:Here are some pics of the newly fitted primary drive chain conversion, 13-30T sprockets.
The recent batch of bikes we have received no longer has air chambers, it is purely spring with no adjustment on the left leg.
I must have the older fork then. BTW, do you have any 58t sprockets laying around I can buy?
motomoto said:I must have the older fork then. BTW, do you have any 58t sprockets laying around I can buy?
I have a factory 58t that I got from "Sun Tong" a guy that works for Sur-ron and and is a dirt national champion in China.
I let him borrow a Sur-ron bike when he came over to scout the US national supermoto series which he is going to compete
in starting in Boise Id come April. I built a fixture and have the Solidworks file which I showed and have a sheet of 7075 material
to carve up. I might make up 52 tooth sprockets because the blanks are 9 inches and the 58t are 10 inches. The sheet is 48.5 inches
wide and I don't want to waste any material. I will get 30 58t blanks and 22 52t blanks out of the sheet I have.
By the way, Sun Tong wheelied the Sur-ron bike in our parking lot in an amazing way, using the rear brake to balance
the bike. So impressive. I have spent untold hours trying to get up to speed with it, and show glimpses of having it.
I should get some video but have a problem of choking when I think others are watching.
In my defense, they were already leaking otherwise I wouldn't have touched themAebrennan said:Do not attempt to add air pressure to the forks without reading the manual first, you may do a Hyena.
Gloert16 said:Just unpacked my new Sur Ron and can't wait to get it out on some trails.
I also got the RST Killah fork and have to admit I was pretty disappointed. I swore I saw it posted somewhere in the forums or on Luna's site that all their bikes would be shipping with the FastAce forks. I'm about 6'2" and 215lbs, so worried I'm going not going to be happy with the RSTs - I also plan to use my Sur Ron up in the Rocky Mountains during Elk hunts, so I'll be on game trails, old rutted out logging roads, dense forest/rocky/steep, etc where the better turning radius and durability/MX spec of the FastAce was appealing.
There definitely wasn't an option when I ordered to specify the fork - which is why I also thought everything would be shipping with the same fork option. I guess I should have asked specifically prior to ordering as I may be stuck with what I got. Any advice?
Blade59rt said:Hi all, new here but have been looking at the Sur-Ron for a while. I was originally going to mod my fat tire bike(electric motor etc) but decided against that after looking at the Sur-Ron. So far it looks to be a great bike. For those owners is this bike what you thought after you received it? Still deciding on getting the bike. Just not 100% yet. How is the power after say a few miles? Does it start loosing power? or stay pretty much the same until near empty?
I also want to use this on some sidewalks to get to some trails, but am considering adding the pedals just to not get harassed to and from.
Thanks for all the great info so far. Dave
m3t said:On Luna's "documentation" site that they lead you to, it states that the Fastaces are production forks, so you're absolutely right. Honestly, I just touched base with them and although it's not set in stone, it's unlikely they'll be swapping them out for free. They are working to get Fastace forks in, and will be offered separately as an upgrade? I'm keeping my fingers crossed. I only have 4 miles on my bike and I'm itching to put more, but I really don't want to kill any opportunity to swap these out for Fastaces. I have a dark grey bike and the white forks are killing me. If they were black I honestly don't think I would mind that much, but the skinny stanchions on top look kinda weak compared to the rest of the bike. Even my roommate said that, which was
jph3 said:m3t said:On Luna's "documentation" site that they lead you to, it states that the Fastaces are production forks, so you're absolutely right. Honestly, I just touched base with them and although it's not set in stone, it's unlikely they'll be swapping them out for free. They are working to get Fastace forks in, and will be offered separately as an upgrade? I'm keeping my fingers crossed. I only have 4 miles on my bike and I'm itching to put more, but I really don't want to kill any opportunity to swap these out for Fastaces. I have a dark grey bike and the white forks are killing me. If they were black I honestly don't think I would mind that much, but the skinny stanchions on top look kinda weak compared to the rest of the bike. Even my roommate said that, which was
Prior to buying two bikes, I spoke with the rep who confirmed they were ‘all FastAce’ going forward. Not sure how this is going to work out, but there was never an ‘upgrade option’ that I was aware of?
**edit. Received a note back from LC. The RST is a $50 upgrade option on the website (just added) and they included it for free to the early adopters.
efMX Trials Electric Freeride said:m3t said:On Luna's "documentation" site that they lead you to, it states that the Fastaces are production forks, so you're absolutely right. Honestly, I just touched base with them and although it's not set in stone, it's unlikely they'll be swapping them out for free. They are working to get Fastace forks in, and will be offered separately as an upgrade? I'm keeping my fingers crossed. I only have 4 miles on my bike and I'm itching to put more, but I really don't want to kill any opportunity to swap these out for Fastaces. I have a dark grey bike and the white forks are killing me. If they were black I honestly don't think I would mind that much, but the skinny stanchions on top look kinda weak compared to the rest of the bike. Even my roommate said that, which was
if you end up keeping the RST forks because you can't get an even swap for the fastace, etc but the white color really bothers you then maybe just paint the white fork lowers black or whatever color you prefer.. you could use vinyl wrap over the existing color and it could be removed later if desired without damage to the original paint.. they also now have vinyl coatings available in spray can (at auto parts store, walmart, etc) for very easy application, again also removable later or easy to touch up if needed.. of course mask off and do not coat any of the moving parts..
Raisedeyebrows said:Could a person put a Fox 40 or some other capable downhill fork on one of these bikes?
