Suzuki GSX-R e899 K2
Wanna add a little bit of light 🤣
So at first step I was creating a template.
I set the cut out to the real middle of the fairing, not to the optical one
Cut out is ready. Now I have to create the mounting adapters.
Tail light incl. Gyro breaking light is also mounted
Well I think they can’t block me anymore from night events 😉
should be enough light for future
Change now some battery connectors
Updated 35 pcs of 6S connectors. So the battery box can theoretically handle up to 882V DC
A little bit of bad news …
First contact with the concrete!
It happened yesterday evening at Bamberg start/landing field.
I was still standing and looking for the sports mode switch but regarding the deep darkness and no lighting I couldn´t see him.
So, it came to the situation that I touched the acceleration switch and the bike pushed forward. Spinning wheel gave him a left direction for short.
I tried to hold it, but the bike felt on the left side.
After first check everything looks ok, but it wasn´t at the end.
I continue with the start. Another problem was that I the chain was to lose.
Therefore, I knew that an aggressive start was not possible.
I decided to start smooth and continue with acceleration.
But also, in this situation I got spinning wheel and drifted a little bit to left side.
The drive was to test the new headlight, but I was not able to switch the light brighter via Bluetooth switch.
I think the converter frequency will block the Bluetooth frequency.
After several meters I felt a hit to my left breast side and first I thought it was something like a small bird (there were several on this field).
But when I came back to the starting point, I figured out that I lost my battery cover plate ☹,
Which we can´t found in the night with our small torch lights. Story continues regarding the cover plate and other stuff. Have to check now the left battery box itself …
Btw. the controller do not switch off during acceleration 🤣C4DDD1BA-13AC-41D3-96E7-76D144BC8A6E.jpeg
Glad that you're not injured my friend!!
Sounds like the bike is going to rip super hard when you get a clean pass in!
Thanks Luke!
Well I already shorten the wheelbase (-4 inch) and do not higher the amps (still at 425A). Could be now the combination of to much air in the brand new wheel (2bar) and the reason of +10 teeth on the rear sprocket. Next step will be to lower the pressure and for sure to adjust the chain correctly and see what will happen.
So they found the battery cover next day on the landing field. That was not so good and I will block now for a while to drive and test there. So maybe in half a year I can continue there again!
In the meanwhile I can only test on the events I will join.
Ok, there are some scratches now on the cover plate and some cracks but Nothing was really splitted!
I will try to repair it 😉
Add now some additional lights
Some? That things has so many lights I'm surprised you have enough battery to make it to the end of the strip! (just kidding, might be a litte envious, wife wants some glow on her bike)
Despite the bits falling, there is some pretty neat fabrication on this thing, I've seen some team builds that aren't as neat. Impressive if you're soloing this
Different battery supply 🤣.
I also add some old stuff now.
Next opening …
Added now the water expansion tank
Ready for take off 😉
Thanks, in two weeks I will continue
I already lower the pressure to 0,75 bar in the rear wheel to get hopefully more grip. So maybe I will rise up the voltage to 600V to try to compensate the greater rear sprocket (45 teeth) to reach 200 kph for sure 🤣
what shall I say … It’s getting faster and faster!
I only made two runs. 1st one on last Sunday and 2nd on on last Monday.
1st: 521V DC, 450A
I started slowly, because I changed to many things at once: 45er rear sprocket, shorter wheelbase (-4“).
So the 60 feet was very slow with 2,2 seconds.
In normal case I calculated 40-50kph less topspeed regarding the change of rear sprocket (-10 teeth) but maybe 40% of field weakening helped!
At 500V (last year autumn) I reached 225kph (425A). And now I reached 217kph at finish line. With a time of 11,68 seconds.
After the run I decided to recharge the batteries and implement another 8 6S packs. So in the evening I reached 630V DC and I also increase the current to 500A, the critical one the controller switched off last year.
I was a little bit excited before the run that I switched off the cam and before I started I thought that I switched the cam on again. But that’s another story 😉
Again my competitor was my brother with my old GSRX 1000 K2/K3.
I did a burnout and lost a lot of rear wheel rubber 😢. The point is that I can change between two driving modes (Normal/Sport: 150A/500A) and I will drive in torque mode. With 150A it’s not possible to get the wheel spinning and at 500A it will increase his speed very, very fast!
Ok but let’s come back now to the run.
Again I started carefully, to avoid spinning wheel or backflip 😉). So my brother came out very good and made some meters …
Regarding his switching problems from 2nd to 3rd I think and the point that I fully open the acceleration switch after few seconds I buzz at him and it was the first time I feel the acceleration like with my old combustion bike and maybe a little bit more!
And there was no feeling that the acceleration will stop after a while.
The complete time (reaction and driving) was stoped by 10,600 seconds. And the real track time was given with 10,2 seconds by 248kph!
But I also counter checked it with my measured values.
Time seems to be equal but topspeed was lower (236 kph).
Nevertheless I am very, very happy with this result. I am pretty sure that it is possible now with this setup to go below 10 seconds but I need time and a bit more practice to get it solved!
And the most important thing is that I did not lost anything (battery, motor, controller etc.)
Btw. I made the first place in the category (electric vehicles 😉) But it was an unfair comparison (regarding weight/power ratio) but the cars have electrical helpers which I don’t have!
Congratulation!
Great result. Must feel good to finally have a very good run with nothing breaking down. Hope you'll be able to post some videos of future runs.
Still in progress! Normal work will block me actually to continue 😢
The short video clip from last weekend
