emotate said:Interestingly, when I top it off with the 2A charger that came with the battery, when it gets to 54.6v the charger cycles on and off every 2-3 seconds for about 2 minutes then stays off. Is that the BMS balancing doing that? The 5A charger from Lunacycle shuts off and stays off.
Some chargers have a circuit in them that latches them off, for batteries that don't have a balancing BMS to disconnect the charger from teh battery once it is full.
Some chargers are made for batteries with a balancing BMS--that BMS then controls whether the charger is connected to the battery or not, so it can balance cells.
If you suspect a balance problem, or test the cell votlages and find one, you should use whichever charger allows charging to cycle on and off via the BMS, and let it run until it stops cycling. On a badly imbalanced pack it can take days.
