passpato
- Joined
- Jun 18, 2011
- Messages
- 89
Can somebody help me please. I am repairing an ebike for a friend. Unfortunately its been messed about with before. Im pretty sure the issue is with the pas sensor or its curcuit inside the speed controller. The owner had already started fitting a new pas sensor and unfortunately I no longer have the old one that was removed. I can make the motor work by fitting a twist grip throttle and using that but I cant make the motor spin from turning the crank passed the pas. Does the wheel need to be turning at the same time as the pedal crank? How does this basic 5 magnet sensor work? I would expect to get a reading across the blue and red pas wires with an ohms meter but I get nothing. I thought I would be testing a coil. How can I test this sensor to see if it is working properly? Can I fool the speed controller with a pulse from something else to test that? Help appreciated.
