I finally figured out a better way to build some a123-based packs. My old method, which created 4s4p "stick"-packs, worked okay, and was easily to configure multiple "sticks" into 12s, 16s and even 24s configurations, but the problem is that in almost every one of my configurations, I really need more than 4p/9.6 Ah. What I really need for most setups is 5p, or 11.5Ah.
What I came up with is to use a similar "stacked" construction method, but this time I'm making use of the plastic end caps that are used in the DeWalt packs. Instead of having ten cells wired in series, like they are in the DeWalt packs, the cells will be organized as two sets of 5 paralleled cells each. I stripped out the existing wire springs, and instead have two 3/4" x 5" copper straps, with five battery springs attached to each strip. Four of these 10-cell packs are then "stacked", and bolted together. That makes a solid 8s5p 24V/11.5Ah sub-pack. I then plan to use two of these, one on top of the other, to end up with a 16s5p, which is exactly what I need. I just started putting these together, but I will post some pictures as soon as I finish.
The other issue I have is that I don't have a good way of sealing these packs from the elements, with a full BMS installed. I can, however, make things pretty well water-resistant, if I just use a LVC board with the pack. What I decided to do was go back to an earlier concept I had where I split the BMS into its two pieces, the LVC board, and the rest as a CMS (Charger Management System. I started down this path with the BMS that Bob and I were doing, early last year, but then abandoned it when I just couldn't deal with the heat issues. Here's what the CMS looked like:
I've done two new board layouts, one for the LVC, which will bolt onto the front of the 16s5p pack, and the CMS, which will mount in the same size box as above:
The LVC includes active cutoff, although I haven't decided whether or not to use that, or go the controller ebrake route. I'm leaning towards doing the active cutoff for these, as it will eliminate two more wires that I won't need to run to where the controller is mounted.
I've ordered the boards, and I already have the parts, so I'm hoping it won't take too long to get this going. I'll post some more pics as I make some progress.
-- Gary
