diatoun said:
Some people have asked if it is possible to use two satiators in parallel but I have not found a clear answer.
I'm using two 48V Satiators (combined with other 36V chargers if needed) in parallel every day for several years, now. It just works. At the end of charge, one Satiator will reach end of charge about 0.1V before the other, though.
the two Satiators are bolted together. The rubber O-rings around them act as feet and prevent scratches
According to Justin, two Satiators connected in series should also work. I've tried it once, but both Satiators indicated a short and switched off (no harm done, they are well protected against shorts). Since I didn't made a proper serial harness for the test, I guess my serial cable rig was dodgy.
diatoun said:
Or if anyone knows of a quality 72v LFP charger over 9A I'm interested :wink:
I've split my 72V battery into two 36V batteries and charge them in parallel instead. Usually, the 36V BMS should not be affected, since each 36V BMS only sees 36V, not 72V. But you should check that before.
For ease of use, I've soldered six XP60 (3 male, 3 female) plugs into a 3x3 plug, to be able to charge up to three 36V batteries with up to three chargers in parallel.
To avoid large current flows between the batteries if you charge them in parallel, you first plug-in every battery alone, note the voltage on the Satiator screen, plug in the battery with the lowest voltage first (usually its not more than 0.1-0.3V* difference in resting voltage between the batteries), start charging and plug-in the other batteries when the charging voltage reaches their respective resting voltages.
*if the voltage difference between the batteries is higher than 0.3V, I'll usually charge them separately
