Per the manual, that's what's supposed to happen in Force Start. It means that there is voltage on the connection points you are measuring at, so if tha'ts at the output of the adapter you're using, then it's working like it is supposed to.synics said:I tested the voltage at the adapter and it fluctuates between like 40 and 70 when pressing force charge
For Force Start, when applying voltage there doesn't cause current to flow, the Satiator will detect this, and give up after a short time, because it means there is something else wrong, somewhere between the output you're measuring at, and the battery cells themselves, that is preventing connection.
For example, if a battery has a BMS, then if that has shut off the input due to cells that have gone too low to safely charge, then the Satiator won't be able to charge it. Probably not the case for yours, given you're not measuring any output at one of the connectors along the way, but is something that happens.
If there is a load on the output so that the Satiator detects current flow, it'll stay on normally, obeying whatever the charge profile it's set to tells it to do.
It's not completely clear what youv'e got for connections going on. It sounds you have the XLR output from the Satiator plugged into an XLR-Anderson adapter, and then that plugged into an Anderson-to-GX12-3 plug to connect to the scooter.I also voltage tested after the adapter where I Anderson connected my scooter cord (gx12-3 plug into 60v 35AH battery) and get nothing. It just says to plug battery. So for that scooter it's either the anderson on the adapter or the something is wrong with that cord somewhere along the line.
Is that correct?
For measurements, it sounds like youv'e got voltage as expected on the XLR output of the Satiator itself, during Force Start. But at the output of the XLR-Anderson adapter, you get no voltage during Force Start.
If that is the case, then something is wrong with the XLR-Anderson adapter.
If instead you mean that you get output there, but not at the GX12-3 plug, then it means the Anderson-to-GX12-3 adapter has a problem.
That's always possible, but there's some stuff to check first:NOW on my other scooter (60v 15AH battery) that has an XLR connection (so I don't need the adapter) when I plug the XLR straight into the scooter it states that it is charging, and the voltage fluctuates again all over. The amps never go above .02. I left it on the charger for 20 hours total and it finally said charging complete this afternoon. So I turned the scooter on and the battery is only at half power. So this Grin Satiator didn't charge it AT ALL. I am beyond frustrated with this piece of crap. It's looking to me like it's defective.
Whenever I've seen that behavior, it's with a BMS that has turned off the input to protect against overcharging a cell that has too high a voltage, because the cells are unbalanced. So all you get is a little leakage current from the Satiator thru the BMS into the pack, at most, and eventually the Satiator turns off output with "charge complete" because current has flowed, but then dropped below whatever you setup in your profile for that battery as the cutoff current.
Does this battery charge normally with it's original charger?
If not, measure the XLR on the battery/scooter to see which pins, if any, have voltage on them, and how much voltage.
If it does, measure the voltage across the charger XLR pins, noting down which pins you have voltmeter red and black on, and whether the meter shows the "-" sign on the voltage display or not, to verify what polarity it is, and which pair of the three pins it is using, and then do the same on the Satiator, and compare them. While many XLR-connectorized batteries are the same pinout, it is possible for a manufacturer to have chosen to use a different one. If they did, the Satiator's XLR wiring (made for the normally-found wiring option) won't work on that, and you'd either need to make an adapter that crosses wires as needed, or rewire the Satiator's XLR, or rewire the scooter's XLR, so that they match.
