today: replaced the old turn signals in front. the leftside signal had been intermittent for a while, then stopped working altogether. the led strip on the same fork leg still works fine, so it's not a wiring issue up to that point. since i have wanted to change to a "fancier" style of signals (that match the rear ones in lenses) i just went ahead and did that, instead of troubleshooting these. but while wiring up the new ones, i found it *was* a wiring fault, broken conductor inside the insulation, between the point the led strip joins the cable and the left turn signal itself. :/
the old signals bolted tot he sides of a "y" frame i'd built into the headlight support. the new ones have their own "wing style" supports (actually they're for the rear, but i like the look on the front instead), but the bolt holes / mounting plate are at a sloping-back angle so i couldn't just put them on, i had to put a matching mounting point on the headlight support. this meant altering the headlight support itself, but at the time i got these signals i hadn't yet figured out how to do it easily.
today, i figured that out just looking at it...poof the idea was there.
just grind the twin tubes at the top at a matching angle to the supports, then weld two "nut plates" i had saved from something (don't recall what) to those. i put bolts in the holes during welding to keep the threads clear, then took them out and reground the faces flat so the signal mounts would sit correctly. bolted on, and voila!
of course, i didn't do it all alone, i had help from my supervisors:
the next thing was to fix the side-looking mirror on the front. since the fork changeover, it hasn't been aimable far enough upward, so i have to lean forward and down to use it to see past corners, parked cars, etc. to fix this, i had to open it up and remove some material from the ball-joint holder of each mirror, so they could pivot farther upward. easy to do, but had to cut the plastic apart to get the unit itself open first, and didn't want to destroy it. so now i can use it like it was meant to be (sort of...it's actually supposed to go on a car's trunk to do this job).
it's still just ziptied to the headlight support frame, rather than bolting it on, but it is very lightweight, so not a problem.
--added an led bar over the kia headlight
now, since it was meant for a car trunk, it has a place for a red light bar in it, for a brake light, etc. but i have it in front...so why not a white light bar? i took an old aquarium 12v led strip, cut it in two sections (with a couple leds leftover that wont' fit), and used silicone to "glue" tehm down inside the mirror unit behind the clear cover area. they're bright enough to see in daylight. presently is switched on with all the other lighting (except headlight and canopy/cargotopdeck lights).
--moved the grin led headlight and disconnected it for now
while i was tying this down, and putting the reflector back on for the left side front (came off with turn signals), i moved the grin tech led headlight from the right side over to the left, above the reflector. wasn't room for it before. the epoxy or whatever casing of this light is aging poorly. chunks have fallen off, and the mount hasn't been part of it for a while so it's been ziptied around it to the bracket on the trike. even the button extender is gone, for the power/mode switch. can still poke it with something to change it, but don't need to. it just stays in the steady-on mode. the outer two rows of leds usually don't light up anymore, occasionally they will flicker at random superfast rates. the middle two still work. i'm only leaving it on the trike at all in case other front lighting fails, as a marker light, since it has such a wide voltage input range i can use it with whatever battery is still working on the trike.
but i left it unplugged, as i have plenty of other lighting up there now.
--removed the failed left throttle after impossible repair attempt
now, this was a disaster. :/ this throttle was causing intermittent problems that took me months to narrow down, and that only happened because it finally died. the problems were that the pas would just stop responding, but throttle didnt' appear to work either. sometimes. sometimes it would. the ca main screen showed the pas sensor input working normally, with the icon in the lower left corner, so it had to be something else. the throttles worked perfectly, so it couldn't be those, right?
i thought it might be a ca issue, firmware bug or hardware issue in the ca, etc.
but then sometimes the left throttle would stick "on" just enough to cause the ca to see a throttle input...which means that it disables the pas control. the right throttle would still override it. but sometimes the left throttle would apparently be stuck at a much higher than normal voltage, well over four volts, and that would disable all throttle input (and the pas). if i flicked the throttel, it would work again, sometimes. then the throttle just plain died, no output at all.
since its' the last of my "good" thumb throttles, i gave it a shot to fix it. no votlage output regardless of connection conditions, input voltage, positon, etc., opened it up and found the hall was ripped off inside, and one magnet floating around in there. :/ well, the hall was an easy fix. i have a bunch of full-grip twist throttles, so i pulled the senosr and cable off one of those (they're not glued in so it's easy), then moved it to this throttle. wired it up, and then began experimenting with the magnet reinstallation positions. it's not quite square, so there's only four total postions the bar magnet can go in. should be easy, right?
i apparently forgot to take pics, but i went thru every possible variation of magnet postion, and could never get below about 1.4v on the low end, up to 4v with some positions. i tried comparing with another similar thumb throttle (with broken thumb tab), but every position seemed to match, everything wa salways attracted, never repelled. after an hour o r two i gave up on it, and decided for now i'll live with just the righthand throttle. i d'nt need itmuch, almost always just ot start from a stop when i can't push on the cranks hard enough without pain, to get started enough for power to kick in.
EDIT (060620): I found the reason for the "impossible" magnet problem:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=37190#p541271
(end edit)
--removed the temporary rigged brake wire/tape system from the right brake lever (front disc). it worked fine but don't need it now, because of the next post's work.
--repaired the rear top-bar red led strip; the left half had gone dead a while back, found a part of the strip had internally corroded under the silicone. cut it out and replaced with new section, soldered it in and siliconed the gaps.
--removed the dead white led strip under the left handlebar
dunnow when it failed, bu ti's toast now.
the next post goes into detail on the prop-regen/brake lever.
which explains why no matter what I did, the throttle would never work. Now that I know this, I might be able to fix the problem, if I ever need a regular throttle type throttle (have been working on changing over to COT (cable operated throttle) units, to prevent ever needing to deal with fixing the problems that happen with these cheap handlebar-mounted plastic ebike throttles).fechter said:The two magnet hall throttles use an interesting magnetic configuration. The low side magnet (closest to sensor at zero throttle) is magnetized radially, that is the poles are faced 90 deg to the direction of movement. The magnet on the high side is magnetized with the poles parallel to the direction of movement.
(end edit)
