Lebowski
building a triple stator axial flux at the moment
24-98v so they are going to rate their controller 2v away from the limit of the irfb4468??? Scary stuff 10awg wires might be OK for interment use....xenodius said:They seem to have the controller up on their store now, but it's just a pre-order: http://velomastera.ru/shop/show_cat.php?catid=5&grid=1
Looks like the final cost is about $800 USD (24,000 rubles). Steep, but it's a VFC... and with continuous regen and throttle kick-down... mmyes, it's what I need!
I can see it now. A dude on a Harley with Screaming Eagles is idling next to me at a light... he begins laughing, right as the light turns green... I'm in low-power mode! I'm only pushing 3kw! But my 6kw motor can take even greater peak power, and my A123 pack can provide it! I twist the throttle all the way down! TWELVE KILOWATTS push me forward as I squeal ahead, thanks to my superior torque response and power/weight ratio! I win, and not just because I'm completely silent and using only 20-60 wh/mile!!
The caps are mounted on the opposite side of the board to reduce stray inductance.boostjuice said:It appears to have a standard linear FET layout
Connectors will be different (better) on production lot.xenodius said:And to see the connectors
bio said:How much more efficent is a sinewave controlled hub motor?
Does it mean that at same outputpower the hub motor stays cooler?
xenodius said:I found out after my last comment that the maximum theoretical efficiency of a 3-phase BLDC with trapezoidal control is 92%.
The efficiency of trapezoidal control at higher speeds can be evinced in RC setups... they use simple trapezoidal controllers but have very high efficiencies in the 94% range.
adrian_sm said:Hmmm. That doesn't match my experience at all. I have been conducting a lot of dyno testing of RC motors, RC controllers, and ebike controllers recently. At low speeds the RC style trapezoidal controllers are not efficient at all, and create a huge amount of waste heat.
xenodius said:adrian_sm said:Hmmm. That doesn't match my experience at all. I have been conducting a lot of dyno testing of RC motors, RC controllers, and ebike controllers recently. At low speeds the RC style trapezoidal controllers are not efficient at all, and create a huge amount of waste heat.
I'm sorry, I probably didn't explain myself well, but that is exactly what I meant. At low speeds, especially for RC style systems, trapezoidal control will be quite inefficient. I assume they're oversimplifying.
