Greetings, I have a Prodecotech Phantom X Ebike with a 36 volt battery and 500 watt motor. The bike originally came with the crappy Wuxing 4 pin ht throttle with the red on/off button. Years ago I bought a spare, but now they are both not working. I also bought a spare generic ht throttle (no on/off switch) which I recently connected but it has a problem. Although it worked good, as far as accelerating, the battery level LED's stay on green, even after the battery gets low, and the throttle gets hot. This throttle did not come with the connector, just the bare wires (red, blue, green, yellow.. which are the original 4 colors coming out of the controller) and the loose pins. I don't know much about electronics but I do know how to solder. I didn't want to mess with this so I had a motorcycle tech do it for me. Even though the colors were connected the same as the original Wuxing, is it possible that there is a discrepancy in the color codes? If so, how do correct it? Which colors do I swap? I should mention that the brake kill switch wires were cut off before I aquired the bike. It was working for many years with the Wuxings. Also, I don't know if the fact that the new throttle has no on/off button has anything to do with it either. I know these are cheap throttles but I now live in Mexico and they are not available here and to get them sent is expensive and risky. Any info, if anyone thinks it's a color code conflict and which colors to swap, would be highly appreciated. Cheers
