safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Throttle Verses Heat
I've been wanting to be able to prove this definitively for a while and now I've got the "spreadsheets" to do it. While it's pretty obvious that good gearing increases torque and reduces heat just by "feel" it's possible to show the exact way that heat and torque are related. The following charts show the differences that take place by comparing two gears. The low gear and the high gear are spaced as 2 to 1 compared to each other. The motor is a 750 Watt Unite running at 48 Volts and a 40 amp controller.
Note the "big dots" and compare the values:
High Gear
Throttle Setting - 60%
Speed - 12 mph
Hub Torque - 51 Nm (which is less torque)
Heat - 930 Watts (which is more heat)
Low Gear
Throttle Setting - 80%
Speed - 11 mph
Hub Torque - 79 Nm (which is good)
Heat - 560 Watts (which is good)
So the "bottom line" is that in low gear you create 40% less heat and get 54% more torque. You also are operating at 65% efficiency while in low gear and 46% in the high gear.
If you need to climb a hill good gears really help a lot.
Speed - 12 mph
Speed - 11 mph
