I have my spares for cross-country stored at middle-volt inside the house where the temp does not swing far. Since I didn’t ride this year, I gave them a little top-off, but they held a good charge… not dropping more than 0.5V from where I left them; let me explain: I keep them unified in series as 15S, so when I say the only dropped 0.5V -
that's impressive. The reason why I picked middle-volt is because that’s how HK ships them.
That said, I keep my Commuter topped-off ready to go so I can bolt to a client with < 2 hours’ notice if need be.
I ride year-around. In the winter, I swap out to studs. This year will be a little different cos I’m running wider rims, so I won’t be able to install the Schwalbe Marathon Winters. Instead I have Schwalbe Ice Spiker Pro on the front (26x2.35) and the Panaracer Fire FR (24x2.4) knobby on the rear. Today I was looking at studs, and found two new suppliers which I added to the
Rims & Tires Reference: It’s probably the same supplier – but there’s a scooter stud that has a shallow penetration useful for us ebikers, but – it’s wicked spendy… like $100 for 100 studs + another $10 for the tool.
I counted the number of block-sets on the Panaracer and there’s 36 of the same pattern, so my thinking is to get the 100 studs, and put 36 on each side (alternating) – so that the center of the tire is clean, but the edges will grip on cornering. The FWD Schwalbe has a monster 361 studs, so I’m not too terribly worried about losing traction. I just a bit more bite out of the rear.
Anyways... I hope your bike doesn't get used to being stored for too long :wink:
Stay safe,
KF
