HackyHackerson
New here
I have a 48v TSDZ2B that I've put on a Ozark Trail G1 Explorer. It came with EKD01 display. Lately the bike has been adding 300-500 watts assist in power level 1.
I discussed the problem with an AI, and it mentioned that there is a crank arm zero that might be an issue. The crank arms have been off, and I honestly can't remember if I put them back on the same way. I never really paid attention to the assistance level before the arms came off, but it seems like it was lower. My range is suffering pretty badly.
I've also updated to the latest firmware for the EKD01 display. Both of those things happened about the same time, so I'm unsure whether I have hot rodded firmware now, or if the crank arms are in the wrong orientation.
Taking the crank arms off and testing is complicated by the fact that I don't have a puller at the moment. I can, and have, loosened the crank arm screws and ridden the things loose, but doing so multiple times for the sake of testing is something I would like to avoid if possible.
TL;DR - Is there a zero orientation for crank arms on a TSDZ2B? If so how would I determine what it is visually? Or, is it likely that the new firmware is hot rodded?
Thanks in advance for any help.
