DeeL2003
1 W
tsellers said:Well, I was fully aware of the caveats on front mounting a hub motor on front suspension, but I see no reason why if the installation is done properly, it cannot be achieved. In fact, I would not even try doing it on steel front forks without torque arms as well. My installation was obviously not done properly. I should have drilled my required holes and done any required grinding first, and then I should have had the torque arm tempered, something which our welder at work may be able to do for me. More info on tempering is here:
http://asuwlink.uwyo.edu/~metal/heat.html
Even the great system posted above by Mark would be prone to the same failure as mine if his slot stripped out and became oval, perhaps taking out his wiring at the same time.
Very true. BTW, was there any damage to your motor? How fast does a 4011 go @ 72v.
