dnmun
1 PW
nope, heating is I^2 X R = Watts. always better to get your power at higher volts, because it takes less amps.
I know that is true for heating through wires, I was just wondering if it carried over for FET's. I know that you may not get as many watts at a lower voltage through the same FET's, just possibly a few more amps at the lower voltage than at a higher voltage closer to the FET's limit.dnmun said:nope, heating is I^2 X R = Watts. always better to get your power at higher volts, because it takes less amps.
tostino said:I know that is true for heating through wires, I was just wondering if it carried over for FET's. I know that you may not get as many watts at a lower voltage through the same FET's, just possibly a few more amps at the lower voltage than at a higher voltage closer to the FET's limit.dnmun said:nope, heating is I^2 X R = Watts. always better to get your power at higher volts, because it takes less amps.
tostino said:I sadly haven't had time for a distance ride (though I did put 45 miles on the bike today).
However, today nearly ended in disaster. Let me explain.
I woke up today, and noticed my tire had heavy wear. The nylon was showing through in some spots. So I took a ride up to the bike shop to pick up a new tire. I didn't have enough time to change it before I had to go to class, so I just said to my self i'd do it when I got back.
So I make it to class, and almost all the way home, and I had to stop somewhere to do a little job for someone. I finish the job and start heading home again.
I am less than 2 miles away from home, going 40mph with cars behind, and in front of me when I hear a LOUD *BOOM* that sounded like a gunshot at first. My tire had blown out, and my back tire was tracking all over the place. I don't have all that much stopping power from 40mph with no back tire. Luckily, it is a 2 lane road with no curb, and grass to the side, so I get it off the road so I don't get splattered all over someones bumper. At this point i'm still going 35 off road, and trying not to lay it down and eat shit.
I finally manage to get it slowed down and safely stopped where I won't get killed, and see it wore through the tire and into the tube, which bursted open. At this point I call my girlfriend, who comes to pick me and the bike up in her truck.
That was a scare for the day. Don't need another one of those for a while.
Lesson learned, should have just taken the car...It's just not as fun(I guess neither is being dead though)
I glued them with Gorilla Glue. That stuff has actually held most things better than jb weld for me. I had a look inside the other day really quick, and they were still held securely in place.dnmun said:that makes sense that it would be 18A for one phase wire connected at a time, versus 37A for two phase wires.
how did you end up gluing the relays? i bet that would be a good place for the JB Weld.
Hey, yes the bike is still working perfectly, and i'll go check the miles now... 1254 miles.Metallover said:Sweet project!
I am wondering what amp and voltage ratings you have on the relays.. And also, can you refresh me on what all you did to mod the controller?
Is the bike still in commission? How many miles?
