Trike powered by wheelchair motor
FlyWheelz
Here is a project I have been working on. My goal is to make this trike go 12-20mph on flat ground and be able to go up 5% grade 1000ft hills from a dead stop. I don't know the weight of the trike(maybe 100pounds) and I weigh 115 pounds. I want to go 12-25 miles round trip which includes 6 of those hills and the rest is flat American river bike trails. Since its a trike, I don't mind going 48v or 60v if I must. I am unable to pedal at all. I need it to be reliable.
I am using a geared motor from an electric wheelchair. Its a 2-pole brushed motor. Would 4-pole be better? I don't know any specs on the motor except that its from a 24v system with two huge small car like batteries (110punds). The 14" wheels would mount directly to the gearboxs and the chair could reach speeds of 7mph. Chair had tons of torque.
The 3/4" alxe with Peerless 100's differential has a 28 tooth sprocket.
The 3 speed Shimano hub with coaster brake has 19 tooth Input and 22 tooth output sprockets. It has 0.75 / 1 / 1.33 ratios.
Currently there is a 40 tooth sprocket on the motor.
For electronic I am using the original wheelchair 80amp controller and joystick.
Right now the trike gets about 8mph in Shimano low gear. In high gead the motor/controller over heats.
The torque is really bad at the moment with 40 tooth.
I also tried a 18 tooth sprocket on the motor and while the torque seemed ok the speed was around 5mph.
I really have no idea what I should do to accomplish my goal. For starters, I would like to buy another controller and throttle. The one from the wheelchair requires a second motor plugged in. Extra weight for nothing.
Please anyone, if you can guide me to next step I would be greatful. I am at a point to just get a hub motor kit.
Thanks.
Below are few pictures.
The 4pole will probably be better--it certainly was for CrazyBIke2, especially for startups, which had been weak and waobbly with the 2pole but really torquey and fast on the 4pole.
For one thing, the 4pole on mine is a heftier motor, capable of more power output just from it's windings/etc, leaving out the 4 vs 2 poles. But you may also destroy the Shimano hub with the power the motor can create, if you slam on the throttle at any point. ;) Apply throttle slowly or use a controller with a ramp up input and it should be ok.
Yours might already be ok, though, if you just up the voltage on it. Catch is that I doubt the wheelchair controller can go higher than 24V. :( You could test by simply taking out the controller temporarily, then wiring in a switch to engage the power--but you need to have a safety cutout that you can yank out of the circuit in case the switch welds shut (it might happen!). I'd put such a safety cutout in regardless, since if a brushed motor controller fails it could fail in a way that leaves the motor on full throttle, with no control over it. :shock:
My first suggestion would be to try a higher voltage, first by just adding another battery or two, but a set of questions before you do:
What is the motor-gearbox's shaft RPM, without a load on it, at 24V? This is probably printed on the gearbox or motor, and it's usually 100-140RPM.
What is the RPM the pedals would input at the same place the motor is doing so, in order to get that 20MPH you're after? This is a little harder since you probably can't measure this directly and I'm sure it's not marked anywhere, but you can calculate it backwards from the wheel diameter, the ratio from the wheel sprocket to the Shimano's output sprocket. If I did it right below, the ratio from input to wheel to output of motor with 40T should be about 2.14, not including the wheel diameter in that. (but I am bad at math concepts so I sometimes make serious mistakes in figuring out formulas and stuff, so check everything yourself. :lol:)
THese questions matter because the original RPM will be multiplied by the change in voltage. If it was 100RPM, then it will be 200RPM if you double the voltage. So then the whole system would double in speed. But that might not be enough, so to figure out how fast it needs to be at the input to the Shimano hub, you can take the speed it needs to be there and divide by the speed it already will be at the motor. Then figure the sprocket you need on the motor based on that and the sprocket already on the Shimano.
The motor was designed for good torque at a certain RPM, and now you're asking it to do that at a different effective RPM (much different gear reduction). It's original RPM would've been whatever the wheels directly mounted to the axle gave it. It's new effective RPM is the ratio from the sprocket mounted on it's axle (40T) to the one on the Shimano (19T), then whatever ratio the Shimano is set to by it's shifter, then the ratio from the Shimano's output sprocket (22T) to the wheel's input sprocket (28T), then the diameter of the wheel.
So that's 40:19, then say 1.3:1, then 22:28, then the wheel.
So 2.11:1 x 1.3:1 x 0.78:1, then wheel.
Or, 2.14 times as fast as it was originally meant to go, before considering wheel ratio. Now you have a 24" wheel, originally it directly drove a 14" wheel. That's about 1.71:1 ratio. So ultimately 3.668 times faster, meaning really it's little more than 1/4 of the torque it originally had.
So a 4-pole motor will by nature double that torque, assuming all else is identical. Since the 4pole will probably also be a higher power rating (you'd want to check that) then it'd probably be more than double. Should still be more than enough to go up those hills, but it might not be able to sustain full speed while doing so.
It'll take at least
Which means that you either need a sprocket 4 times the teeth of that 18T, or you need a voltage 4 times as high. Or a sprocket twice as big and a voltage twice as high.
Meaning with a 40T it's a bit more than double the 18T, so you can double the voltage to 48V and theoretically get 20MPH out of it. That particular motor may or may not be able to do it by itself, so you can try either using a pair of them in parallel, both outputting to the same chain (whcih can just wrap around the sprockets on each one), or use a bigger motor.
Well, you could mount and use the second motor, putting it into the same chain as the first, so the chain wraps around both sprockets, one from each driveshaft.
I am using a Curtis golf cart controller now, and I have also used a 2QD controller from http://4QD.co.uk . The only reason I switched was because I SEVERELY overloaded the 2QD (about 3500W!) and while I was working out some alternate ways of setting it up in a box and heatsinking it, I fixed a Curtis 1204 that had been donated to me. The 2QD works fine, too. Both can work up to 36V and with mods at least 48V. Some versions of either work at 48V out of the box, and I think even higher, but I think 48V is all you need.
In theory a hub motor might be "simpler", but might not work as well over the hills as the geared system, or at least not as power-efficiently (forcing you to carry more battery to do the same work). However, the hub motor could possibly perform regenerative braking down hills and such, regaining a few watt-hours here and there, making up for the other losses, perhaps. It would be difficult to know the regenerative effects until you had the system operational and in use. The freewheels in the chain system prevent using regen with the wheelchair motors. :(
I am biased towards fixing up the wheelchair motor system, because I know they *can* work, and they are a creative way to solve a problem, where a hub motor is more commonplace. :) I use both, but I like the idea of the w/c motor better. Which one you should use depends on which is more practical for you, though.
I asked someone else I know about the stuff above, and he verified the numbers I came up with are close enough, or about 3.79x faster than with 14" wheels directly driven on the gearbox shaft.
He also thinks that motor was originally used in something that would only go around 5MPH not 7MPH, which would've been 120RPM on a 14" wheel.
So if his assumption & calculations are right, the no-load speed of the trike wheel would be (with each of the Shimano gear ratios available):
10.2/14.2/19 MPH (40T)
4.5/6.4/8.5 MPH (18T)
If it is actually supposed to run at 7MPH instead, then it'd be 14.8/19.9/26.5 MPH (40T)
6.7/8.9/11.9 MPH (18T)
Since it is not doing that (if i understand correctly) then there's probably not sufficient power in just one of the motors to do it. Higher voltage may help, but probably it will need both motors.
It may also be possible to parallel the motor outputs from the wheelchair controller, but only if they are sync'd. To do that you'd first need to ensure that the control stick cannot create any sideways movement. If you have an oscilloscope you can verify if they are sync'd or not.
He also said that there's a ""motor balance" parameter used to compensate for any minor differences in motor RPM to keep a chair from veering that would have to be checked for equal motor output PWM." I have no idea how to do that, as I haven't used any wheelchair/powerchair *controllers* yet. It is possible this is an automatic thing, and not manually alterable, I suppose. In that case, parallleing them would require high-current diodes from each output to the motor, and would preclude ever using the reverse function, which you would probably need.
He has a helpful tip for the joystick part:
"To prevent any side-to-side joystick movement from sending unequal PWM output he should also cut the leads to the two direction sensing coils on the joystick inductive."
That sounds simple enough, but I havne't seen the inside of one yet, so it might not be as easy as it sounds. :) THe same method can probably be used to prevent any reverse signal from being generated, if you wanted to do that for any reason.
There is so much good info in your posts that it will take me a minute to really get it. This is my first time seeing this stuff :shock: I will keep posting more answers as soon I figure them out.
It is not printed anywhere :( But I found this formula [Diameter * RPM / 336.14 = MPH] So its [14" * RPM / 336.14 = 6.5] Then RPM is 156, at top speed of the powerchair with load, so maybe 200RPM no load?
I also found out the original batteries are 12v 75amp each, 24v total. The Controller rated at 80amp, powers 2 motors, could we figure out Watts of motor? Is it 24v x 75a / 2 = 900watts per motor? And a controller to get should be 40amps for a single motor? Would this work http://cgi.ebay.com/48V-800W-brushed-speed-controller-e-bike-scooter-/300366446835?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item45ef3c40f3
More to follow...
Could be, but that'd be unusual in my experiences so far. Even 156RPM sounds high for 24V.
Well, just because batteries have a capacity of 75Ah (not just 75A, the H for Hour is important), the motors won't be drawing power that way. ;) It just means that theoretically you could draw 75A for one hour, or one amp for 75 hours, before totally draining them. (Due to Peukert effect this doesn't really work out that way, but you get the idea).
The watt rating of a motor is it's capability to dissipate power (heat) and perform work, before destroying itself from the effects of heat and/or mechanical failure from stress. Most often powerchair motors are underrated, from what I have seen, if you were to add a cooling solution (ducted air, etc) they could be run at 2x or 3x their rated levels. Maybe more. :) Definitely more for a burst. I doubt that they are 900W motors--perhaps as a pair 900W total, but probably not even that. Any rating they did have is going to be a continuous one, meaning you could run them at that for as long as you like and they'll take it, probably. SOme might only be rated for 30-60 minutes of that power level, becuase the batteries would never last more than that if you pushed them that hard.
Most (cheap) scooter motors (and their controllers) tend to be OVER rated, with the numbers advertised beign their *peak* output rather than continuous.
If you had a watt meter, like a Cycle Analyst, Watts Up, or Turnigy Watt Meter, you could put that inline with the system and see what power levels were actually being drawn in various test conditions. I discovered a lot of good info after getting one. Just multimeters don't give the same information, as they do not include time in their readings, and things happen too fast for you to be able to manually monitor and log the data while riding.
Assuming 80A is 40A per channel (motor), then 24V x 40A = 960W nominal peak output from the controller. I don't know if that is a sustained rating or not, and it doesn't mean the motor could sustain that either, without overheating. Usually these peak power levels are only needed for a few seconds at most, when starting from a complete stop, not constantly. If you tried to go up a hill in the original chair these were on, drawing that much power all the way up, it'd probably shut the system down from overheating to protect it. (Although with only 75Ah batteries, 80A draw would only last about 15-20 minutes anyway due to Peukert loss on lead-acid).
[/quote]
Well, as for the amp rating, it's tough to know what you will need without actually measuring what the motor is drawing right now. 40A is theoretically enough, since I'd guess that it would have 40A peak per motor intended on the original setup. But your repurposing is likely to draw a lot more than that, since you're using the motor in a different way to do even more work than it originally did.
As for the controller, I don't know if it'd work or not. I strongly suspect it would be insufficient, as that 800W is probably a peak rating rather than constant. Plus, if you divide 800W by 48V, you get only about 16A, which is not going to be enough, and your motors would probably blow it up with any sustained current draw at the levels I think you will have at startup or on the hills.
There are online calculators (like the one at http://4qd.co.uk ) that can help you figure out the power levels you'll need to sustain some specific speed with a specific vehicle/rider weight, on a specific slope of a specific length, most of which numbers you probably already have, making it fairly easy for you to find out how much motor power you will really need. And thus, how big a controller you will need, too.
amberwolf , I decided to go with a Front 9C 6x10 direct drive hub motor. The reasons behind my choice was I wanted something very reliable and something that has been tested on the road, and dogman did a great job here. My setup has not been tested, has things that could fail like the two chains and shimano hub, plus I needed a controller. Plus, due to the fact I can't pedal, the thought of something failing far away from home scares me. The DD setup, has a lot less things that could go wrong with it, in my opinion. So I hope I made the right choice. In the back of my head I still see geared mid drive setup something as a backup for really steep stuff or just incase DD fails I could crawl some distance for assistance.
I do want to thank you for all your help and your time to post. You tought me a lot.
I can see why the hub would be a good choice for you here. I may still borrow from your setup for something myself, later. :)
You should keep the other bits around for later re-use, though, as you might find a backup vehicle useful, or one for another purpose, that could use that setup. :)
