4500km in, I feel it might be time for some maintenance and fixes/upgrades and I'm running into some issues I would love some opinions on. Also got some questions regarding OSF for stock displays on DZ41 from Enerprof, I guessed it should be fine since it's acting like a stock display but not 100% sure.
I was still using my old x3 10s derailleur, but as I was having lots of shift issues not fixed with new cable / pulley wheels ( and the thing being decade's old ) I bit the bullet and bought an l-twoo a7. I bought the set initially, as I wasn't 100% sure the issue wasn't with the shifter itself ( and I needed the rd anyway since my old Shimano xt rd won't fit larger cassettes ) and only after riding some with the L-twoo shifter I realized how much I'm used to being able to drop down using my index finger. And I realized the A7 rd and my old ml610 shifter have the same pull ratio. That part seems to be riding smooth now.
Now, I been getting a bit of a 'crunchy' sound now and then I felt, not sure where from but I felt I should grease the gears just as a precaution anyway. And, as I found my motor to be really hard to pedal without the motor on, and wasn't willing to rma it or gamble a new combined gear would solve that ( I have no reference how 'light' this should feel.. or not with another Tonshen.. my daughter's Bafang M200 rides like a normal bike when the assistance is off.. my bike feels like I'm lugging a 20kg cargo cart ). Either way, I noticed that while the bearing is sealed, there is a small gap. So I been using a non ptfe silicone spray to spray on the gear assembly, then rotate it a bit and wait to let it soak in, then spray a thick layer, rotate ect ect. It seems to be really making a difference, I can feel it's turning much smoother already.
But, I did misplace my circclip pliers which means I will have to go deeper after I buy a new one. But tbh, it almost feels like the only crunch I had was within that dual bearing gear I been lubing the heck out with silicone spray, I want to check the status of my blue gear anyway.
I was wondering if this silicone grease would be good for the blue gear later on? ->
Griffon siliconenvet 15 gram in de beste prijs-kwaliteitverhouding, uitgebreid assortiment bij GAMMA
www.gamma.nl
I also bought a DZ41 in the clearance sale at Enerprof.. without checking beforehand to be sure it would work with OSF. It should, as it acts like a stock display so I should be fine just swapping my xh18 with the DZ41?
I've had some faults/errors riding in really wet conditions, and I'm not 100% sure what the cause is yet. I just lose all assistance suddenly, I get an error message most of the times ( couple of times I couldn't see an error message.. and stupid me couldn't tell which the error code was, it's to small to read from my seating position without glasses for sure ). The only way to get rid of it, is turning the bike off and on again.
I suspect perhaps my xt60 battery connector, so I put some additional electrical tape over it. But I don't feel it's that likely, as the other time I had an issue on that part of the loop I had vastly different symptoms. I left my bike out in the snow, took the battery inside with me but didn't put a bag over the cradle. When I got back, even clearing almost all snow, some was still left when I mounted the battery. This snow melted off course, and as I result my battery indication went from 'full' to 'red/near empty' really fast. Waiting wasn't really an option, so I just drove on hoping I would make it home and I did. And it doesn't seem it caused any permanent damage, to both the motor/controller as the battery itself. But, if there was an issue within the xt60 connector, I would expect the same behavior as with the melted snow on the battery cradle ( connector ).
I also noticed I lost the little 'plug' from the cable which goes from the motor to the speed sensor, and which has the optional cable attachment option for lights ( where you get this yellow plug to keep it water tight ).. yeah I lost that one. And spray is certainly getting into that connector. I don't plan on ever using the lights through tsdz2b, I just ordered an EOS630 and as such I feel I should probably just hotglue that connector 'shut'. Or put some silicone in the plug itself, fold some electrical tape over it, slide some heatshrink over everything and use that to keep everything in place. Anyway, there is no doubt water gotten into that plug, could it cause an error which would cut out all power?
The other thing I know about, is the gear sensor tripping after slippage. And after 4.5k km without maintenance ( ... oops ) I guess this would be a possibility but a> why would this only happen in really wet weather b> wouldn't I feel the slippage just as the sensor would? The only reason weather would trip that error would be if it somehow got inside the motor and caused slippage due to water ingress.
Probably more likely my derailleur issues could trip a sensor, if the controller feels something 'slipping' it might think it's one it's internal gears even when it's my chain?
edit: btw, was thinking of grabbing +5 and ground from the display cable and pass that through my bike light so it's always charged. Shouldn't be an issue right?
edit2: well I guess I should prepare for some water ingress in the main housing. After soaking that gear in place for so long with the bike on it's side sure did pool up some lubricant inside... putting my bike upright had it coming out right on the seem between the left and right main housing. I'm off to the shop now to get me some new circclip pliers.
Edit4: darnit I still can't get past 15kmh with the motor off... I was wrong btw, it's way worse then towing my bike trailers constantly with them
I eventually will get up to speed here it's not happening. And my knees start hurting like heck within a hundred meters, it's still a nightmare if I get stranded far from home without power I will likely park the bike somewhere and get a taxi or something, charge my battery at home and take a taxi back instead of trying to pedal it home... and that sucks. I thought I bought the motor which got the 'upgrade' so you could ride it 'like normal' but compared to that bafang m200 this thing just ... sucks. Ofc, when I do have power I really like it... so I will just have to make sure to never go anywhere which might cause range issues
