Cheers guys, at least its sort of looking the part, the functionality of it
atm could be improved-->
The surging issues is still haunting me, i have also blown a cap in the ESC
and the 3 speed Sturmey Archer, well..its just crap, i strongly advise anyone thinking of using
an internal 3 speed to re-think this option. The sprocket attachment method is less than
satisfactory IMO, Matt.P will back me up with this im sure, the amount of lateral movement
the sprocket has is quite frankly rubbish, makes chain/belt alignment an issue, under hard
acceleration the sprocket moves, with a belt, it spits it... with a chain, it aint going to sound to flash
and i would envisage premature chain/sprocket wear...haha if the internals of the hub actually
lasted more than 5 minutes..
SO..my bike is now parked up for the time being...last night i laced up the spare
20x4.25 rim with the chrome extra wide freewheel hub Matt.P picked up from
ChoppersUS for me last order i have ordered a ENO freewheel from sickbikeparts
wont be here for at least 2 weeks though closer to 3 likely, this will replace the Sturmey Archer -->
As can be seen, there is also a blown cap on the ESC not sure why this happened the
bike wasn't even moving when it blew, i was placing the lid back on the battery
enclosure when the bang and flame happened :-S Still runs fine ..well as it did before...
I have also replaced a cap and added a resistor to the fechter interface in an effort to
eliminate the surging issue, it hasn't completely eliminated it. This combined with the
sync at start up makes the bike rather dangerous for me to ride, i need a smooth take
off to get upto 'balance speed' its fine if i use the actuators, but i dont like using them
on the road much, if i am taking off from a 'T' junctions for example. its very difficult,
you either launch forward unable to turn to make the corner (if you do you tip over when
actuators are lowered) and run off the road OR i use my feet down and take off hoping
it will be smooth enough not requiring the strength i dont have to keep the bike from
falling because there ESC/interface aren't syncing or i get surging happening...Once its
up past 10km/hr or past ~1/4throttle its fantastic! ooodles of power and its smooth...Everything
before 1/4 throttle needs fixing...
SO...options...first i am chasing a speed controller...Luke suggested one of
Lyens 18fet speed controllers $us159 + $us25 postage=$us184
fair price i guess BUT ITs
TEN INCHES LONG ffs..aint gunna happen soz Luke, wont fit in my enclosure and theres no way known im bolting the monstrosity on the frame anywhere...Option two...A Kelly
mini speed controller As someone mentioned 'they are on 40k electrical rpm" well actually they are'nt they have an option for 70k electrical rpm if you lose certain pointless options..reverse...regen..etc.. SO..will 70k electrical rpm cut it for a Turnigy on 66v? If so...problem solved the Kelyy is acceptable size ie. size of packet of cigarettes.. Option 3..and TBH i nearly took this one a day or so ago...buy a cyclone 1500 watt motor and speed controller..I already emailed Paco he can do me the motor and controller for $us470 delivered to my door... Sad to lose the RC motor but it will be gone only as long a it takes for the fellas to sort out hall sensors, the cyclone would be an intrim solution only, i could use it on the Huffy drifter (plastic trike) I have
after that instead of the nancy frock motor i was going to whack on the front wheel for the lads to have fun with (
and NO Luke i wouldnt have ridden it...on camera anywayz and denied all knowledge to the contrary
) ...So thems the options i have come up with, if anyone else has an ideas im all ears...
KiM
EDIT: Forgot one..I emailed Keywin ie. ecrazyman regarding the infinions he has, quoted me $us100 delivered for a instant star programmable 72v 45amp controller..He said "but the controller has stopped use the infineon XC846 MCU ,it is use XJC8B116A but stronger than XC846 " I have no idea what model/size this is or if it would even be useable, anyone tellz me what the deal is with this unit as the price is better than all...
