John in CR
100 TW
I hope you're joking about the poly resin. At least upgrade to vinyl ester resin. I wouldn't waste good carbon fibre on poly.
John in CR said:I hope you're joking about the poly resin. At least upgrade to vinyl ester resin. I wouldn't waste good carbon fibre on poly.
Hopefully it's OK. It's probably just a matter of getting the halls positioned right and then the right combo. Even with the wiring arse about you should atleast get some stutter or jolts from the motor.AussieJester said:Biggest issue is if the controller is still functioning
i could get the right hall and phase combo but the controller maybe dead :-S
Shall fiddle with it for awhile till i get discouraged...will report back on the progress.
AussieJester said:I took the Turbigy from the cruiser late last night, decided i would make up a bracket for Burties
halls sensor mount and play with this today see if i can have any luck.
I have several things against me...Biggest issue is if the controller is still functioning
KiM
Hyena said:I have a lil frock motor here I can send you to test it.
John in CR said:Hey AJ,
Before you go cutting up Hyena's frockie, don't forget your RC motor is just a little candy-ass frock motor without it's little baby size wheel. :lol:
John
recumpence said:Ooo, ooo, that sounds like a challenge!![]()
Matt
etard said:Nice brakes bro! I just picked up some Juicy 5"s myself. What kind of exercise machine will you be building into a jig? I would like to know what to look for if anybody has one free around here. Damn those brakes look good, let me know how they feel.
AussieJester said:Ahhh bugger, I thought the new bike of yours was going to be up and running pretty soon John?
You have the chassis in rolling stage now....
gwhy! said:Hi KiM,
What is your current draw with your motor no load on 44v.
Cheers.
AussieJester said:gwhy! said:Hi KiM,
Cheers.
Hooked up to the driveline wheel off ground or 'free standing' motor hooke to nothing ?
I read yours was high through the gearbox of the scooter your converting so though i best clarify.
KiM
gwhy! said:AussieJester said:gwhy! said:Hi KiM,
Cheers.
KiM
Mine draws a tad under 6A no load , not connected to anything 'free standing'
HAL9000v2.0 said:Is this hole for CA?
IF YES THEN SHOW us how you mounted CA below.
