Offroader said:Alan why did you decide on the 6s 8Amp hour packs. I am considering the 6s 16 amp hour packs because they are the cheapest. Did you do this because of size and fit?
teslanv said:I can fit 3 6Sx16Ah Multistar's on each side of my Top Tube Saddle Bag. That's over 2KW of juice.
And it fits OVER the Triangle Bag.
Offroader said:I assume you meant 6?
Nice, yeah these 6s x16 AH ones add up nicely in Watt hours.
The price is also so good and better than any other hobbyking lipo for the 16 amp hour packs. I really find no reason to get any other batteries unless you really can't meet the amp demand. I find my 20C turnigy packs a total waste of weight, volume, and money in my bike as I never get close to their total amp output.
KINNINVIEKID said:Offroader said:I assume you meant 6?
EXACTLY.
A pair of these Multistars can cope with everything a BBS02 can throw at them.
After half an hour browsing ebay I realise I am going to have to make my own top tube panniers for them.
This comes as a major disappointment to me. I was counting on fitting 4 into an EM3EV triangle bag and had just assumed they'd fit without taking measurements. Currently, I have it filled with 12x 4S 5AH hardcase and if I tidied up my wiring harness I could fit another 4.KINNINVIEKID said:I love the 16Ah for simplicity of charging BUT can only get 2 in my EM3EV bag so am looking at getting smaller ones to fill the space properly as mentioned above.
Anybody have one of these and how do you fill it?
5P starts to create problems in as far as grouping into sub-packs while maintaining convenient shapes (2x2 is neat and gives flexibility, but 2x2+1 not so much). With a tidy, minimal wiring harness you could get 15/16 in, but only just. Don't plan on getting anything else in though.KINNINVIEKID said:Now you have me thinking!
If I could fit 15 of those hardcases in that would be 3S5P for 25Ah and would cost £240
The Multistars are 16Ah for £180 so a similar cost per Ah but of course the hardcases weigh quite a bit more.
Can you definately get 15 in the EM3EV bag?
neptronix said:That's bad news that only 2 will fit in a falconEV bag.
You'll get 25% less watt hours per square inch with the hardcases though, plus they are some of the lowest quality packs that hobbyking sells. I don't recommend them at all.
For you, i'd say add some 10ah multistars on top of your 16ah. There will be a way to make it fit. 26ah of 46v nominal is a huge amount of range for a BBS02.
danielrlee said:5P starts to create problems in as far as grouping into sub-packs while maintaining convenient shapes (2x2 is neat and gives flexibility, but 2x2+1 not so much). With a tidy, minimal wiring harness you could get 15/16 in, but only just. Don't plan on getting anything else in though.
Yes. I am trying to get 32Ah mostly in the triangle .neptronix said:Hardcases are the least energy dense packs you can buy. 10AH turnigy multistar will allow you to jam the most capacity into that bag. That's your goal, right?
Alan B said:If the em3ev bag I ordered shows up before the Multistar 6S 8AH packs are installed on the Borg, I'll do a check fit to see how those work.
It would be good to try different combinations and see what options work well.
riba2233 said:18650 are better in many ways, and there is a wide range of C ratings. What Would be your C rating?
