Hi, today I (with some help) managed to brake my second half-twist throttle. It's an em3ev model, lovely feel, the one that has the 3-speed infineon switch and cruise. http://em3ev.com/store/index.php?route=product/product&path=41&product_id=91
Both have broken in the same way and I think it's fixable. I borrowed the bike to a collegue to take a ride and he kinda panicked and after accelerating, in order to brake in stead of releasing the throttle and press the brakes he just over-untwisted the throtle body, like to brake with the throttle. I heard a crack, plastic-crack-type.
The way the throttle works now is fine unless it's released (like at zero volts) and on what is supposed to be zero it sends something like 1/3 throttle signal, or close to that effect. The follwing situation occurs: I brake/stop at a light, release the throttle and the bike jumps ahead from under me
; it can be solved by cutting the power at each light, but it's anoying... Today I borrowed the bike again and the second throttle started doing the same as the above, while the throttle seems to have a bit too much play.
I have two questions basically, do you have any advice on how to fix/debug or have you seen this type of 0=30% throttle fault?
