Miles said:
The fundamental frequency will be low enough that stock 0.35mm laminations will be fine. This will save a lot on what is probably going to be the highest cost item.
It's rare to hear such a good piece of news in a project
Intuitevely, the single-sided bearing should work fine - just look at the stub-axle arrangement on most road-going vehicles. Nowadays a double-row ball race, formerly a taper-roller. If the rotor isn't subject to axial loads then a straight roller ought to do the job (the efficiency of roller bearings falls drops as the angle increases). I suspect it will always be a heavier design than double ended as the bearings will see greater load if the distance between them is less, so they'd need to be bigger and the axle would need to be stiffer.
However, the absolute difference probably isn't that great, and may even be offset by the savings of only one structural cover. Plus the design simplification...
I know plastic is tacky, but vac-formed polycarbonate could be a good option. Very cheap and tough. The equivalent weight of cast Al would be rediculously fragile and even spun sheet would be prone to dents (and artisan to produce).
The cassette-drive idea is sounding better. Initially it seemed to greatly limit the potential motor width compared to a hubbie, but I like the idea of it being plug and play with any cassette wheel you care to pick up. No more custom lacing jobs or big headaches if you bend a rim.
Would anyone be kind enough to clarify the issue of gearing? Will the SRAM gear hub reliably take the motor power? Will the efficiency be an issue?
Forgive me if this is a stupid question (I'm not at home so can't check the chainline on my bike), but is there enough space to mount three sprockets on the remaining cassette splines and use a derailleur? Then only the human drivetrain is through the gearing.
Either way, is three-speed on the rear enough for the serious cycling enthusiast who might want an expensive, featherweight motor such as this?
