Hi All,
I have this controller https://www.ebay.ca/itm/Ebike-BAFANG36V-250W-48V-500W-750W-Brushless-Motor-Controller-Replacement-Kits-/352866679972
and a Bafang DPC18 display all connected to a Bafang geared hub 500W geared hub motor. I don't like the way the pedal assist works. Each PAS level relate to a max speed and the power kicks in too sharply even in PAS1. I want to change it so each PAS level relates to a max power level, ie. PAS1 125W, PAS2 250W, PAS3 350W, PAS4 500W up to PAS5 750W. Also that it doesn't kick out 20Amps as you start to peddle. I think it should step up the power in stages.
How do I do this? (I don't really understand what needs reprogramming - is it the controller or the display). I see there are programming cables for BBSHD mid drives, but would they work with my controller?
Any help would be much appreciated.
