Hi everybody,
here is my new project bike I want to convert my postman bike to electrical with a :
- Tongsheng TSDZ8 48v 750w VLCD5
- Tongsheng TSDZ2B 48v 500w VLCD5
- Bafang BBS02B 48V 500W.
• Desired max speed on level ground 32km/h (off road).
• Desired max range at what cruising speed 45 km/h.
• Preferred bike wheel size : 26x1,95 (53 - 559) rear tire size (front is 24').
• Brake type of motor wheel : front V-Brake (maybe Magura HS 33 R), rear original drum brake
• Rider weight : 80kg, (extra material carrying up to 100kg).
• Terrain. Exp: mostly flat, some short hills under 10% grade.
• Budget : 800€ (bike included 100€).
Here is my actual configuration :
Here is my composant list, there's some double as I haven't choose anything at the moment. I'm just starting to look at it :
If you got some advise into building my electric bike, I will be glad to know it, here's some details about my needs :
- I think i really need the torque sensor as I don't really like the moped style.
- I'm not sure to change my 5 gears, sprocket set I will be glad t use the same in a first time also because there's no option to buy a 5 gear Nexus inter5 a bicycle hub with spoked rim (it's quite expensive in France). Other alternative is to buy a Nexus inter8 ZAC2000 for 172€ or keeping the original Shimano SIS with 5 gears sprocket.
- I don't expect to go very fast but I will be glad if I can climb some 10% roads, up to 100km, with a well-loaded bike up to 130kg. That's why I would like to buy a motor bigger than 250W, because I would like to be able to carry a lot of weight without difficulty.
- As I live in Marseille I'm also looking for solution against robbery, I plan to use a U-lock, with a frame lock and also adding an airtag, he will spend his night safe at home.
- Also I will be very happy if I manage to have an Open Source Firmware !
roue avant 24' | 44 - 507 | 24x1,75 | |
roue arrière 26' | 53 - 559 | 26x1,95 | |
Boîtier pédalier à clavette | 68 mm | BSC/BSA 1.37" x 24 TPI (34,8 mm) | longueur de l'axe : 136 mm |
Cassette | 14 - 24 dents | 5 vitesses | SIS MF-Z015 |
