peterjd
Since there are (or have been) friction drives marketed with automatically variable contact pressure (ie between drive roller and tyre) to mitigate slip eg in the wet, I am wondering if I can fit a simpler user controlled variable pressure 'trimmer' (the basic pressure against the tyre is spring controlled) on the 'cobbled together' friction drive which I have fitted to my old Bickerton folder? I am thinking of something adapted from a cable or hydraulic brake, so that I can temporarily apply additional contact pressure to the tyre when on a hill or on wet roads to reduce slip and increase traction. Any thoughts? Incidentally the converted Bickerton is quite fun in the dry and on flat or relatively low slopes - is relatively light and still foldable so goes easily in the car boot. Peter
