!!!!!Measure the diameter of the motor. It is important!!!!!
1- remains unchanged value should be 1
2- maximum 110A
3- remains unchanged value should be 9960
4- maximum phase current in sports mode the value must be 150A (but to activate it you must have a separate button for sports mode) Do you have one installed?
5- remains unchanged value is good
6- remains unchanged value is good
7- remains unchanged value is good
8- it should not be more than 34 in my opinion put it to be 0
9 -the value remains good
10 -try with (minus)-60 ° but I think for your engine it should be (minus)-120 ° - However, your motor is QS and may be 0° normal. Do this with very little force with the handle, and you can also read about your engine here in the forum to be sure of the angle. It does matter which phase the voltage starts to flow from. See the table below.
11- uncheck it, let it remain blank
12- uncheck it, leave it blank
13- Set a value not greater than 99%. should not be 100%
The factory default setting was 99% for me, I did it for 100%, and after giving the power to the motor, gave it a short circuit and turned off my feeder, I no longer set a value greater than 99%
