I think I need to retest what I checked during the day. This controller is really... strange. What I noticed: (my) controller does not apply the full power after it's started. It takes some time/wheel spin/throttle movements to reach the top performance from standstill. Today I did it like this: turned it on, stall tested (WOT+brake), measured some stuff, took pictures of the app, hopped on the bike, tested if/how much it wheelied and what I could subjectively feel, stopped the bike, reconnected the app, took pictures, turned it off. It came out it actually "pulls" better if I first warm it up. WTF? So I think I just need to go and test it on the spot where it lost its juice last time, like SilentEnduro did. In fact the more it's abused @ stall, the more it looses on the next start - it needs to... I don't know... cool down, forget about the stall condition?
I also have some more interesting data. I measured the peak phase amp shot on the go. Two different phases, two shots, 356A and 365A RMS(!), so about 500A max (I set the phase current to 9999 in the app), and this is good news. Picture here: https://www.dropbox.com/s/e9g1qa30d56tj26/votol%20em150sp%20max%20phase%20current%20measured%20356A%20and%20365A%20RMS%20different%20phase.jpg?dl=0
And the last thing, very important to me. Listen up... I made tens of start/stops today testing out this stuff. I was so pissed off that the bike did not pull hard enough from standstill. It could barely wheelie - but it should, considering my gearing and over 400Nm on the wheel (in theory, based on what the Chinese say, did not measure it yet). So I started the app and put max or min values everywhere, like lvc 10V, all the start-torque options (for 3 wheelers [
to 255, and activated the fw (3000) and the flux compensation 100, even though I didn't want to use it. Soft start on and off, saving it like 3 times to be sure. Ofc I tested (almost) each option before with no luck. Guess what. The bike started to do this (in sport mode): https://www.dropbox.com/s/zk0roimnrragdqt/Sport%20mode.mp4?dl=0
So the current rising speed changed BIG time. BTW high mode still sucks, a vid to compare: https://www.dropbox.com/s/krf4zwt15nh8zb5/High%20mode.mp4?dl=0
So I started to revert param by param in the app. Do you know which sucker takes responsibility for such the change in motor's response from the start (in my case anyway)?
Flux weakening compensation. I restored the config to what I had before and left fw comp = 100. It's a different bike from the standstill. Why? I have no idea. Note I set both fw values to 0 (in every mode), just left the fw comp set. I don't think they got the ipm motor covered and been using Id from 0rpms.
Though, as it does not change the "overheating" problem, but maybe the hit will not be such painful when it occurs? I will check it out probably during the weekend.
SilentEnduro, SilverLine, please do let us know if it changes anything in your setup. BTW my gearing is x7.33 atm.
This is my current config: https://www.dropbox.com/sh/kvo30kngy7pp651/AADuTnmmjtDs4XgH8VNozWkpa?dl=0
Note the manual says 95 is 100% for fw comp, but I set it to 120 anyway [; I don't trust it.
