Votol em50-4
United Kingdom
Hi could any help with abnormal error while connecting em50-4 controller to pc
My battery is 48v so need to alter settings
What software and lead should I be using
And has any one had any luck with the Blue tooth style lead
If you go to VOTOL EM 50 4 72V Programmable CAN LIN Controller
It shows the cable ...I'm also having trouble getting it to connect using the correct cable ... Let me know if u find something that works
Hi Geraint. If you are using the wiring harness supplied with the controller, make sure Pin 9 on the 16 pin controller has battery positive (B+) voltage applied to it - run a wire from the B+ terminal on the controller to the purple/grey lead on the wiring harness, via the white connector. This will enable the controller and it will start talking, as applying power alone isn't enough.
