Some gasoline and diesel cars have an Exhaust Gas Recirculation device (EGR). During times when the sensors pick up a taste of (hot) unburned oxygen in the exhaust (which contributes to NOx), a valve opens and some of the low-oxygen air is re-routed back into the intake system. It is overly complex and prone to malfunction because the valve must operate with split-second timing and survive its entire life in the very hot exhaust system near the engine. In order to improve its performance a split hair more, the return loop passes through a heat exchanger to cool the 500F+ temps to near the 180F of the engine coolant.
Just more layers of complexity with additional failure points. Go to a constant RPM mini diesel, and much of the clutter goes away, reliability goes up, and the exhaust gets cleaner (with the engine running less than 10% of the amount of time it did before, when used in a plug-in hybrid).
Dramatically reducing the need for imported crude oil can overturn oil-fed geopolitics, and all of us deficit-spending our future economy into the toilet to fund wars and conflicts in places that need us to act as an example of how well things can work, instead of a benevolent slave-master. Hybrids using bio-diesel can help a great deal. At $5/gallon, we can grow our own fuel and create jobs right here. The engineers at VW did what they were told, so now...tell them to do this.
