What do you call the M14 flange nuts for hub motors?
kylerlaird
Rensselaer, Indiana
I bought a bunch of M14x2.0 flange nuts for my hub motors. The problem I have with a new build is that the flange is a little too big - almost 29mm. Bolts that came with some of my motors are 26mm. The larger flange conflicts with the head of the screw I'm using in my current dropout (Messingschlager Fat Bike Hi Tensile Fork).
How do I find some more of these minimal flange nuts without buying kits full of other stuff?
I don't see any M14 flange nuts at McMaster. Their M12 nuts have a 26mm flange, though, so they're obviously "large flange." (I'm making up a label since I don't know what else to call them. "Fat flange"? "Do these flanges make my nuts look small?")
I look at:
Click:
System of Measurement
✓ Metric
Thread Size
✓ M14
Nut Type
✓ Flange
Thread Pitch
✓ 2 mm
See 11 Products. Click Product Detail to see drawings and dimensions.
I look at:
Click:
✓ Metric
Thread Size
✓ M14
Nut Type
✓ Flange
Thread Pitch
✓ 2 mm
Ah! I was clicking on the individual categories and looking through the sizes.
I should have done the search. Thanks!
Unfortunately it looks like the minimum flange diameter they have is 28mm.
--kyler
Just forget the flange and use a nut.
I'm ready to do that. I'd assumed that flange nuts offered a clear advantage in this situation, but I'm not seeing it. It's a 14mm nut that undergoes very little pullout stress and shouldn't be tightened hard. What's the purpose of the flange? Sure, the serrations aid in keeping it tight, but I'd feel a lot better with a stop nut. (My torque arm fully captures the axle, so even with the axle nuts removed, the axle won't budge.)
Thanks for the suggesting this. I feel more confident going this route now.
No! don't listen to some random stranger on the internet. Better to hire 12 or so engineers, mechanics, and bicycle experts and get 12 or so different answers to the same question.
You should be fine with out a flange, but a washer in it's place may be a good idea.
I have plenty of bikes without flanged nuts, but I always use a washer, keeps the dropouts from getting chewed up, and can spread the pressure evenly.
Yes, if I were going into the dropout, I'd definitely need a washer or two. There will be a steel torque arm under it, though, so I think that should suffice.
