www.evlogix.com
This throttle device is now being sold at http://www.endless-sphere.com/forums/viewtopic.php?f=9&t=11877&p=180070#p180070.
Now, back to the original post:
Hey, my company is currently designing a microprocessor based solution to using a throttle on an RC system. I'm trying to understand what you'd look for in a device like this, so I'll explain what it is first.
It's basically a device that allows one to use a regular hall/pot throttle on a RC ESC. Since it's digital in its design, it could also have a load of features such as data logging (Like recording your speed, distance, time, voltage, current, altitude etc. over the ride), a display of some sort, it could be attached to a security system, advanced current limiting (Like say you limit it to Y amount of amps for so many seconds and then a limit of X amps turns on - useful for high current bursts without killing the battery, esc or motor from overheating), low voltage cutoff, temperature protection and ultimately programmability. With programming, you can decide if you want current limiting, you can specify the advanced current limiting settings, you can program what you'd want to see on the display, etc. It's also a current controlled throttle, so more throttle = more current and ultimately more power, kind of like a motorcycle. It's not like a crystalyte controller where above some throttle amount going up a hill, more throttle means the same amount of current and, conversely, less throttle does not necessarily mean less current and what "real" throttle range exists is pretty small and hard to control. Half throttle would mean 50% of the top current, 25% throttle means 25% of the current limit, 100% means full current. So, it feels more responsive and natural.
It also comes with high quality LOW ESR capacitors that are essential to running e-bikes and other EVs on ESCs, so you don't have to add the capacitors yourself. Of course, you could add your own capacitors if you want.
How is this better than say, hacking your own throttle together? You don't have to buy a BEC, a servo tester, add your own capacitors and basically do a lot of work. You also get fairly important motor and ESC temperature protection (Killing $100-$200 ESCs gets expensive!), customizable throttle ramping, customizable current limiting, advanced current limiting, a more natural throttle response, and you can extend it to do datalogging and you can display critical information using a display. There are other devices that could be developed for it in the future.
So, right now, I'm just trying to figure out what's the most important to have as there's only so many sensors that the processor can work with at the same time.
Right now, I have on it..
-Current limiting
-2 Temperature sensors (Can be used on anything, like one for the ESC and motor or batteries)
-The throttle
With the previous, one could customize a current ramp, advanced current limiting and temperature sensing profile.
The temperature sensor works using a pullback scheme. You program what temperature you want the current limiting to begin, and it decreases the current limit as temperature increases until it completely shuts off at the cutoff temperature you program. Usually, the decrease in the current will result in less heating which means your bike doesn't just shut down, it just slows down. This helps to protect $100+ ESCs and motors from dying from over-heating without forcing you to be stranded but you could also ride without temperature protection - it's upto you.
Data logging would be possible with another device and the same with the display. Right after I get this going, the display will be designed.
There are other possibilities that could replace one or both of the temperature sensors. There could be a programmable low voltage cutoff or a pedelec sensor, or anything else that might seem desirable. Could you guys rate what would be most important for you?
Also, how important is weather-proof-ness? Weather proofing makes it more costly to develop and would increase the price by a noticeable amount and ESCs typically aren't weather-proofed, so I think whatever needed protection for the ESC and batteries could probably be used for this device. But I don't know, how important is weather-proofness? How much extra would you be willing to pay for it?
Here's some screenshots of the settings changing program in its current state. More features will be added and programmed in the future!
-Current limiting
-The throttle
