MitchJi
Hi,
I think Matt posted that when he hits a hill, with the throttle held steady the speed is maintained pretty close to the original speed.
I think if engaged remains on until disengaged or the brakes are engaged would be safe.
www.evlogix.com said:MitchJi said:Hi,
Matt said the HV Esc's do a pretty good job of maintaining speed. In any event being able to choose a setting and have it maintained until a brake is applied would be (IMO) a good start. The brake cut-off could be either mechanical or electrical.www.evlogix.com said:Cruise control would be possible if it detected speed. It doesn't as of the current version, but a speed detector may be possible through an add on display or possibly an add-on speed detector.
Wait, so the HV Esc's have a speed limiting function so you could limit the motor's RPM to a certain amount? That's cool. The current version already has an e-brake input, so it seems that could be as simple as adding wires for a user-provided cruise control push button. I'm not yet up to the task of designing things to be held onto the handlebars, but hopefully that'll change with development of the display.
Or it could be a cruise control setting that always on unless the e-brake is engaged, but that sounds like it could be dangerous.
