Rusty123
I know that if power remains constant, the higher voltage will be more efficient, since there would be lower amps, and therefore lower I^2R loss. However, in the real world, it seems like high voltage = higher speed = higher power = less efficiency.
I'm planning to put a Bafang BBS0X crank drive on a recumbent, with the primary goal of long range. I have the BBS01 (350W/36V) on my commuter bike, and it provides me with adequate power, so I'm inclined to install the same unit on the recumbent. But I can't help but wonder how the BBS02 (750W/48V) would compare in terms of efficiency. (Although to be honest, I'm not totally confident that I'd have the discipline to stay out of the throttle).
Since the BBS01 and BBS02 are different motors, with different windings and such, the answer in this case might be different than if I were simply comparing different voltages for the same motor (like a hub motor, for example).
Comments?
Comments?
