Am testing and trying to figure out the wire thickness needed for a certain project...
I know that voltage isn't part of the heat created inside a wire due to resistance and only current applies to that but I have done some tests a while ago testing the same current with lower and higher voltage and the higher voltage produced more heat in the wire and I don't really have an explanation for that.
My case here is that I'm building a 180S battery to transfer 40kW of constant power with 60A current.
I have less experience with high currents at constant rates and wire datasheets tell me nothing as they rate for very high conductor temperature which is useless to me (telling me a 1mm2 wire can handle 30A and such...come freaking on).
So I thought about dual 6awg for constant of 60A, meaning 30A on a single 6AWG.
I would really like to go with dual 8awg but I don't wanna risk it.
Would like to hear some thoughts
