romandesign
I got a new Wheelspeed Taurus ebike that doesn't come with a tail light. It has an S830 display. I ordered some colour Y-cables to tap into the cables without cutting anything, and a 48V tail light with running light, brake light and turn signals. I found a couple of combinations of ground and +48V with a multimeter. And when I close circuits with a tail light it works fine, as long as S830 is off. But if I turn S830 on, and close any of the ground-to-+48V circuits with the tail light the electric horn sounds!!! I don't get it, because it happens even if I don't use the blue cable (that goes to the headlamp and horn).
Now I'm lost... I got 3 Y-cables, and here's how I intended to wire it. Blue cable goes to headlamp and horn, yellow to swithc with headlight and horn buttons, red to the right brake lever. But something doesn't add up...
