SlowCo
Although I'm too dumb to understand most of how this all works, I'm very grateful for all the hard work and dedication Neptronics and others put into this forum for us to use and enjoy!
Someone replied on the old site, lol..Did something change in the software? Today I got an email notification of a reply to a thread but the link in the email took me to the ES Graveyard version of it Nanjing far driver controllers - Page 21 - ES 1.0 Graveyard
SamRich post_id=1749385 time=1697659119 user_id=35824 said:Sattva Ram post_id=1742683 time=1670629563 user_id=69920]<break /><break /> [QUOTE=AdR post_id=1742675 time=1670626012 user_id=79156 said:I have a ND96530. Running a 24s battery which mean max voltage of 100.8V. Had to set nominal voltage to 79V in order to get over voltage protection to show 99.8V. They definitely have some serious series# to max voltage calculation issues. This now show my model # to be 79530.
Okay so nominal sets overvolt. The question is whether overvolt sets regen protect volt too...well i'll check it soon i guess...
I had an issue where regen wouldn't kickin unless I was below 80V. Turns out you need to change the Full battCoeff under the PROTECT section. I had adjusted the Full battCoeff value initially to get a better gauge estimate for battery capacity but apparently it was too low and messed up the regen.
I increased Full battCoeff from 1100 to 1300 and regen worked at 84V!
[quote="Sattva Ram" post_id=1749386 time=1697671512 user_id=69920]
Hmm thank you. This is great to know. However you dont want it to work at 84 cause it'll blow your mos if the bms shuts off...(unless you have split port but none of the good bmses use split these days i wonder why not tho to prevent such situation). I'd totally put it back to 1100 tho or thereabout if i was you. I'll try to fiddle with it and see if it worx. I never even really fully charged my battery so far and regen as weak af but i was very afraid of blowing the fet with the FD. I just blew a votol cause of too strong a regen and an improperly set regen protect voltage...anyway i think i'll sell the FD and go with the votol so it doesnt really matter anymore.
But it does respond to a quoted phrase by actually showing things that have the entire phrase in it....but it still *also* searches for things that do not have that exact phrase, which makes it hard to find certain things that have very common terms in them.
Ok, it's there in "Use Default ES2.0" skin, (and in the within-a-forum search), and appears to have the described functions but:
--searching the results doesn't work, if that's what the search box on the right is supposed to be for (that seems implied by it's existence within search results, as starting a new search should be done by clicking the search again at the top right, or the Search link to the right of Home near the top left, etc; a whole box just to bring up a new search doesn't seem like it would be useful, just a waste of screen space?).
Sorting options are limited to Date, relevance, and Most Replies. Could we add to sort by thread starter/author, subforum, (had somethiung esle in mind too but was distracted by the JellyBean needing a bellyrub).
FWIW... I use 'dark mode' via Firefox (118.0.1).
FWIW... I use 'dark mode' via Firefox (118.0.1). Search box open (Options): Everywhere, Threads, This Forum, This Thread
Except for whoever decided how things work was...less capable and thoughtful than one could hope for.Xenforo seems to be quality software all around.
