You need to trust me on the PAS. I don't understand what you mean by complexity. It's 5 minutes work to fit the sensor and one connector to connect. That small amount of work will pay dividends. I've never met anybody that tried this sort of system and then decided he didn't want or need it, and, in my experience, most people that say that they don't want or need it, never tried it. Xiongda give you the Pedal sensor in the kit, so there's nothing extra to pay.bigoilbob said:d8veh said:It would be stupid to skip the PAS function. That's the best thing about the control system. I guess you've not used one before.
The LCD has 6 levels, each one gives a different current when you pedal. Level 0 gives no power with PAS or throttle. Level 1 about 60w, level 2 about 130w, 3 about 230w 4 about 350w and 5 gives maximum up to about 750w. Go up one more level and the display changes to "L", the motor reverses and the winch is engaged with maximum power, which you get at speeds up to about 5 mph, then the back emf starts to reduce the current, so you typically see 350w to 600w when climbing depending on how fast you're going.
When you use the throttle, without PAS, it works normally, except on level zero, when you get zero power.
Here's the battery I use:
https://bmsbattery.com/ebike-battery/684-48v116ah-bottle-09-panasonic-battery-charger-battery.html
Respectfully disagree on PAS. Don't want it, don't need it. Unneeded complexity IMO. My app will be on a tandem recumbent, and the Captain will command the throttle. You disagree, but don't think it makes either of us stupid. Many thanks for the battery info though. Again admitting my ignorance, how do you get 52 volts out of it?
52v is easy. A 48v battery charges to 54v, so just charge it up and switch on.
