You can say that again. I was on my way to work!
Ypedal said:Got to work !!! used 3.4ah ( my usual hub motor 48v BMX will use 1.8 !!! )
I hope i make it back tonight tho.. the 2nd stage #25 chain is giving me trouble, not sure if it's a bad bearing or if the chain alignment is the issue, or if the 45t gear if warped but something is grinding/pulsating in there once she warms up... .....
Might be just me having a bad day at work, but the more i ride this bike the more i like my hub motors....... :|
No, it just SPANGED and bent the ring, at the leading edge during that rotation. I am guessing it was slightly misaligned, and all that torque.... Chain is fine, I'm fine, bike is fine, chainring is artwork.oatnet said:Wow! Hope you are OK. Did the chain snap?
Ypedal said:This is my 4 year old LiMn packs, 36v 20ah each, they are 2C cells but with 40ah worth 2C is 80 amps..
oatnet said:Those 5 degree C temps bring back bad memories of life before we moved here - it was typical 71 F here today with typical clear blue skies
-JD
Ypedal said:I ran up and down the street a pile of times at like 20% throttle adjusting the gear range and staring at the C.A. i can cruise on 20 amps up slight grade and 12 amps on level ground if i hold the throttle every so still.. more mileage to pile on and re-evaluate..
oatnet said:Ypedal said:This is my 4 year old LiMn packs, 36v 20ah each, they are 2C cells but with 40ah worth 2C is 80 amps..
Are those the Falcon specials from summer of '07?
-JD
lifepo4ever said:I hope we will see a video one day
Ypedal said:oatnet said:Ypedal said:This is my 4 year old LiMn packs, 36v 20ah each, they are 2C cells but with 40ah worth 2C is 80 amps..
-JD
Yep, that be them.. Pack 1 has a dented cell on no.9 ( got it this way from fev ) that has caused it to show a 0.6v drop but somehow still survives, Pack 2 is relatively in good condition, they show their age that's for sure, I suspect the RC bike will kill them off..
