Youin luxor bicycle config menu
Hepc
Hello anyone has any idea on what passwordi need to enter to access the config menu? Its a youin luxor ebike
the subforum below may be a good place for your post
EBike Electronics Hacking
"Discussions about liberating prebuilt bikes from artificial restrictions"
Since they are just trying to get into a menu, I don't think that's the right place. Based on the stuff that's there now, that subforum seems more for people creating systems or software or whatever that are intended to help everyone (i'd assume) get past the restrictions.
If the OP of this thread were creating a passwordless system or software to get past that password on "any" system maybe it'd be good there.... ;)
@Hepc there are a lot of threads and posts asking for passwords for various bike systems; I'd recommend looking them up and trying the ones people have posted in case they work on yours. by thread Search results for query: password by post Search results for query: password
On the other hand, except for your reply, this thread doesn’t show up in either of your two queries. That subforum just seemed to be a place where it might not get lost, so it may eventually be solved, and if it is solved, a place to store the resolution.
Probably because the OP didn't spell it correctly ;) , and the xenforo search doesn't automatically include things other than exactly what you type. It does accept an * wildcard which will force it to do that for things in that spot (like at one end of the word or another, to force it to search for plurals and singulars, etc). (but generlaly the XF search is pretty terrible)
Doesn't really matter to me, I was just doing logical deduction from the description of the forum and the threads that were moved there by whoever created it or shortly after.
however, if this thread goes there, so do all the other password threads. What else has to be moved there too? All the speed limit removal threads? All the shunt mod threads (because they bypass the limitation of current)? All the BMS removal or bypass threads, because they remove the limitation of being able to set the pack on fire after damaging the cells from overcharge or overdischarge? :lol:
