ZeroEm said:
If your controller is in the bag, would find a way to get it out in to the air.
You just gave me a good idea for an ebike saddle bag. A saddle bag where the controller forms the bottom of the bag, with only it's heatsink exposed.
That would be great. I forget it's not as hot in other parts of the world as down here in South Texas. Heat is always on my mind.
Don't ride as far as I want yet but would like to do a 700C recumbent and keep the weight down. Make it as clean as your build.
Framed Alaskan 26”
17” frame
Fat bike
BBSHD 46t (42t Lekkie being shipped)
Lekkie buzz bars 160mm with left crank offset to correct Bafang motor “Q factor”
Micah Tolls BMS 52v 14s 30amp continuous
Tesla Model 3 cells - 0.1mm copper 0.2mm nickel Kwelder
Moosetreks triangle bag
52v nominal 25ah 1.26kw
Hello everybody,
I am new here and I believe that this is the right place to introduce myself.
I can see a lot of beautiful bicycles here, I hope you will like mine.
I am from Serbia and I can say that I'm highly inspired by Vintage electric bikes, so I decided to make one of my own.
First, I bought old frame that could be remodeled how I wanted. Then, after a lot of metal work I can present to you my ebike.
Some of the specification are:
- 500w motor
- 48v 10Ah battery
- 26" tires 2.35"
- top speed 35Km/h
- hard tail (front suspension)
- autonomy around 30 kilometers
- hand crafted, hand painted
- alarm inside the box
- key start
- LED lights
- 500w motor
- 48v 10Ah battery
- 26" tires 2.35"
- top speed 35Km/h
- key start
- LED lights
Ooh that's sharp, I really like the aesthetic of that bike a lot! Nice build!
Can you guess which is Before and which one’s After? ;)
Bought the RANS Stratus XP XXL on BROL Classifieds, without wheels or seat for a significant reduction on price + shipping.
https://flic.kr/s/aHsmSjMFd4
No PAS, just dual half-twist throttles (and two separate displays!)
Limited the top speed to 12m/20kph because over that I’m either riding level ground or coasting so don’t need assist. With the two 52V 21Ah Luna DireWolf battery packs concealed under the seat, on assist level 1 the range is well over 100 miles fully loaded in hilly terrain and likely around 200 otherwise. Can tow more than 100lbs extra (bike itself + panniers and trailer weigh ~125lbs, I’m about 180 warmly attired) up the steepest grades at 10.9mph, which is about four times faster than I could make it alone (if at all.)
Have lids for the 6-Gallon blue buckets, but first need to drill holes through their sides for the power cables (just picked up the 7/8” 22mm hole saw) then line with Dow insulation board for the winter. And of course gotta tidy up the cables, waiting on more 12AWG stranded copper. Planning to coil up the excess harnesses and conceal with an Xmas wreath (no kidding!) and wrap all the rest of the exposed wiring along chopper bars and around controller boxes in blue tinsel as a festive holiday disguise. :p
Oh, and also building a matching blue Igloo 48Q trailer from a Wikes kit. Local box stores all out of the 1” square profile aluminum tubing I need for this project, so could be a while.
Will post back upon completion.
Thanks for looking!
7bXGgL3F6rbP4u7QA
bought this bike about a month ago, striped it down to this. Had an idea to make and all wheel drive bike with lights. Has brake lights, indicators, high beam and some illuminating underlights.
rqoGpXQW36eYc11u7
Before:
After
https://www.youtube.com/watch?v=_8eurhe04MY&feature=youtu.be
My second COVID lockdown folding bike build. Its comically small.
Folding Steel frame
1000w 16’’ Hub motor
Arctic Hunter Crossbody Bag
Lotus Quick Release Bracket
Turnigy lipo 20ah 12c 18s Battery
Maxed out Sabvoton Controller 200A
OK, here are my before-after-after-after pics.
This was the original, a folding bike from the 1960s:
I converted it to a "folding mountain bike" in the late 1980s by adding a 5 gear hub and strengthening the frame by some welding.
30 years later I added a suspension fork.
10 years later I added the front hub motor (350W) and a 36V/15Ah battery.
First attempt-battery+controller on a rear rack:
Final state (battery+controller in the middle section):
Evspark lite 60v 105A
Before:
Kinda... Over time I replaced a lot of parts.
New Ti Frame:
Now the only original parts from the Bianchi are the brake/shift levers. When I get a set of levers I'll put that bike back together.
After:
My commuter...
Oil cooled Bafang G311 standard wind in a 20" wheel, Baserunner, 2x 52V 24Ah EM3EV batteries (+Satiator), Cycle Analyst. Pedal first with PAS ring (no PAS), minimum speed of 8kph and inline brake cut-offs.
Keeping it legal for this part of the world... 200W maximum (240W electrical). Hard limit in the controller.
Here the final results of my enduro build starting from a Specialized Enduro EVO:
Motor: TSDZ2
Battery: 12S3P 21700 --> 650Wh
BR
Silvio
Sun Baja Cruz7 steel frame 3.5 “ tires
Added BBSHD 48v 13.5 ah battery and rear rack
Bike took the 100 mm BBSHD very nicely, good chainline, motor centered in frame. No headaches to the install process, feels incredibly solid on the road. Mainly used to ride around local beach areas with my son in a kids seat that attaches to the front stem or both my kids love riding in the tow behind kids trailer
This is the first Ebike I’ve put together, actually, first ebike ive ever rode for that matter. Within the first few pedal strokes I was grinning ear to ear like a madman, totally hooked
Motobecane Hal Boost Eagle 27
I just got into mountain biking last year. My knees aren’t so good so the option of an electric motor made it possible. I paid $1699 from bikesdirect. Seemed like a decent price.0A2BD2B6-9355-4B84-BDE0-10D486B77EC6.jpeg [attachment=1]1D7CB75A-9B53-43E8-B4DD-41641442C8C6.jpeg[/attachment
I added the 100 mm BBSHD w/42t chainring and 52v 12ah battery. 27.5x3.00 tires
The bike rides very well off road,it works great in all 12 gears. In highest gear I can pedal comfortable up near 30 mph.
Only 2 things that bother me are the battery not fitting within the triangle and the motor hanging a little low. This thing has been insanely fun to ride. And no, it looks close but, the tire doesn’t hit the battery when the fork is compressed.
