In general, the MTA 156 connectors can take up to 18ga wire, so you should use 18ga or 20ga for the cell tap wires. The main pack + and - wires need to handle the full charge current, so this depends on your charging setup. 12ga is usually good for up to 20A. I think the holes can accomodate up to 10ga. If you're using a smaller charger, you can use smaller wire.
