zombiess
It's official, the controller is spinning the motor. I need to sort out all the parameters so it works correctly, but I have some success getting the motor to start spinning in drive 1. When it tries to switch to drive 2 I run out of current, but I'm only testing with about a 6A supply so I know my FOC measurements aren't correct either, just wanted to make sure I didn't have sparks and smoke first.
Dead time looks like it could be set as low as 450nS which give me a theoretical 44khz operating frequency according to the formula in Lebowskis documentation. I decided to go for 500nS dead time to play it safe. Setup the controller for 15khz PWM and 11khz sampling.
Motor is a 46 pole hub motor, 13.23 KV, 62uH inductance. Any suggestions on settings to improve how it runs, doesn't always want to start off in Drive 1 when I give it throttle, but I noticed I have some nasty 60hz interference on my phase wires, to the tune of 4V P-P! I was able to get it to run and drop the interference down to < 1v by connecting the ground of my +5v isolated supply to the B-, no physical earth ground, everything is floating. Haven't been able to track down the source of the 60hz in the circuit.
Time for bed, what a long night and now I won't get much sleep, but it was worth it since the motor spun.
