This topic arise from the Pajda´s idea in another thread :
https://endless-sphere.com/forums/viewtopic.php?f=14&t=102387&p=1507776#p1507776
Frustrated and tired by never ending unfruitful debate about cycle life of various Li-ion cells, I finaly decided to start some long term cycling to see the real results. Parameters was chosen in effort to imitate real utilization, but on the other hand to get some results in acceptable time. Important was to not use parameters like 100 % DOD, 0,5 C charging, 1 C discharging, as these are in my opinion too severe and unrealistic in the real life.
As representants of the typical cells was chosen LG M36, Sanyo GA, Panasonic PF and Samsung 29E7. Chosen parameters for high energy cells M36 and GA : charge 1A to 4,1 V, 5 minutes wait, discharge 2,5A to 3,4 V, 5 minutes wait. For „middle energy“ cells PF and 29E was discharge modified to 3,3 V to keep the same DOD. This is working for M36 and PF, to my surprise GA and 29E are quite out of the DOD range.
In the hindsight discharge could be lower, maybe 2,2 A .
Regarding using terms 1C, 0,5C, …. This terminology is on one hand very useful, on the other hand it is means that for example discharging SONY VTC5A at 2,5A and Samsung 35E at 3,4 A is considered as the equivalent load to both cells. Which is not true.
Equipment : cycle tester ZKETECH EBC-X0510 (8 channels), true 4-wire fixture BF-2A, electronic load Maynuo M9712, DMM GW Instek GDM-8351, thermometer Omega HH 520, K thermocouples.
ZKETECH EBC-X0510 and electronic load Maynuo M9712 calibration was checked with the help of DMM GW Instek GDM-8351, DMM Brymen 869s and 10 miliohm 0,1% etalon Riedon RSN-10-100B concentrating especially to long term current stability. ZKETECH EBC-X0510 accuracy is better than 0,3 %, Maynuo M9712 accuracy is better than 0,05 %.
True 4 wire fixtures BF-2A or its similar predecessors are used for all measurement including cycling. Ambient temperature is in the range 25 ± 1°C for DCIR and 25 ± 2°C for cycling.
DCIR is measured according IEC 61960-3:2017, paragraph 7.7.3. Measuring parameters are unified to 0,6/3 A at cca 3,74 V for all cells.
Here are first data in the graphic form :
It is always useful to state as much relevant data as possible. All these data are useful for those who are in bussines and also for author, to remind in future immediatelly the conditions during measurement. Without them is measurement not very credible. Authors of the reports should also be able to answer additional relevant questions.
