recumbent said:
Ypedal said:
in most cases, adding power results in the same range.. you just get there faster !
If he had a 40 amp controler, would his distance be roughly halved if used same throttle? Or does it not work that way, :? I never quite understood amperage.
Easiest way is to remember that power in and power out will always balance. It's the variables such as wind resistance, etc. that can change the outcome in a noticeable way.
So if you had a 20 amp controller running 72 volts, that's basically 1,440 watts of power maximum you can throw at the motor. If you have a 40 amp controller running at the same voltage, that double it to 2,880 watts of power to send to the motor. What you have to keep in mind is that it doesn't always take maximum power to run the e-bike.
If a 20 amp and 40 amp controller e-bike were riding side by side, given the same bike setup, same motor, same battery voltage, battery AH, etc. The only difference would be resistance. So, if both bikes were going 20 mph down a level road, they would use the same power because neither has hit it's maximum to maintain that speed. But, if both e-bikes were to go up a steep hill, say over a mile long, all of sudden, the 20 amp controller is maxed out and can only maintain 10 mph up this steep hill, while the 40 amp controller e-bike has power to spare and tears up the steep hill at 20 mph.
So basically, you are using twice the power to cover the same distance in half the time. But in the end, the distance is the same, it's just a matter of how fast you got there. So if you can burn out your batteries with a 40 amp controller in 15 minutes and cover X amount of miles, in theory (given a perfect world), the 20 amp controller would cover the same distance, it would just take twice as long.
So think of the amps as the force needed to maintain a certain speed and the voltage as the controller of such and such speed. More voltage, wheel spins faster, etc. More amps, wheel spin speed doesn't change, just how much torque is behind that wheel spin.
Another way to think about it.
If you have 4 different people, each can run 20 MPH, that wouldn't mean that if those same 4 people were to carry a heavy box that they should be able to run 80 mph right? Of course not, it doesn't make sense to add up their top speed that way. What the 4 people can do is carry a heavy box faster than a single person, but only up to their top speed. Same thing when talking about volts and amps. Sure, the volts give you the speed, but without the amps you have nothing to push with.
