Riverbend Bicycles
- Joined
- Jan 19, 2011
- Messages
- 12
First let me thank those that created, maintain, and contribute to this amazing forum. What a great place to learn. I'm starting this topic to show my progress on my E-Fatbike. This is my first attempt at a motorized bicycle as you will soon realize. I've built most of it from scratch because there's not much out there that fits 4 inch wide rims and tires. The tubing is 4130 and most of it is .049 wall. Some unique features are; rear suspension pivoting on the bottom bracket and the modified girder fork. The motor I'm using is the 1500watt BMC from thesuperkids.com. This will drive the freewheel crank which drives the extra wide Sturmey Archer 3 speed hub. The batteries are Ping 48v-30ah LiFePO4. So there's the progress, now the problem. When I finally got the batteries mounted and everything wired up, I was so excited to try it out. I noticed it was very, very sluggish right off, but continued to try and pick up speed. I made it .05 miles when it finally gasped and died. I could smell hot plastic coming from the controller and sure enough, after taking it apart, had fried at least 2 of the capacitors and probably more. I immediately knew I had a gearing problem, but I didn't realize how bad it actually was. So here is my gearing set up. 10T on motor to 44T on crank, 30T on crank to 25T on hub (actually 20T, but the hub gives me 25% in 1st gear). I found a gear ratio calculator on motoredbikes and plugged everything into it. Given that these tires are 26 inch but have the diameter of a 29 inch and the 4800 rpm that the superkids list the motor as, the calculator says I can go 112 mph in 1st gear and something like 210mph in 3rd. Do you guys feel that this is correct? If it is, it's no wonder the bike didn't want to take off very fast. I'm surprised it moved at all. I'm pretty sure I need a jack shaft and another reduction, even though I don't see this on very many ebikes with brushless motors. Playing with the gear ratio calculator, it looks like I'll need another 3:1 or 2.5:1 reduction. Here are the speeds the calculator gives for each of the 3 speeds of the hub. First with 3:1 jack shaft 23.6, 29.5, and 44mph. With 2.5:1 it gives 28.3, 35.4, and 52.8mph. If it's possible to go 30-40mph with my setup. Which of the jack shaft ratios would work the best in reality? I should mention that I've ordered a 24T for the crank and a 23Tfor the hub and also a new controller. Any advice and answers will be greatly appreciated.
But enough about the problems. Here are some pictures.
Modified bottom bracket to accept bearings.
Modified Noleen forks.
Frame before motor and batteries.
Bike before batteries.
Motor and controller.
Bike loaded down with batteries minus fried controller.
I plan to eventually enclose the triangle and rear battery, but that's a long ways down the road. I did install a Cycle Analyst, but need to know what maximums to look for (watts, amps, etc.).
