Time to make a "new years resolution ...." gonna get a motor that I KNOW will do everything I want, unfortunately, that was NOT the goldenmotor 650W trike motor, it was pretty good, but on serious hills, it just wasn't enough for when I would loose my strength after a long ride, AND I want to be able to haul cargo.
My first impulse is to get another CroMotor, but I will check and see if there isn't something in the middle between the 9C 9x7 which is close but not quite enough, and the 5000W continuous CroMotor.
I will be running a 48 - 74V system (A123 prismatic at 48v 20AH or 74 LiPo 18AH if that isn't able to perform as needed) and I am looking to climb hills with about 450 lbs of cargobike, (that is total weight including the rider, bike and cargo) up a 10% grade for about 2 miles on a regular basis.
I really like the near silent operation of a DD hub motor, and with the NuVinci N171B IGH, I will have tons of gearing to use, with a target of 20 MPH on the flat,(and as close to that as I can get to that speed climbing) while still having reasonable range of around 30 miles.
Anyway, here are some preliminary drawings of my planned build:
(The basic design will use the through holes already on the R-40's main beam, I am hoping probably too optimistically to use the QR skewers which are for the seat mount, but I expect I will end up using larger bolts, but I really want some form of QR fastener for easy chain tensioning.)
(Here is a drawing of how I would design the two side plates to attach constructed out of 1/4" steel, hopefully the local college and or machine shop have a way to bend the steel that thick, that or I will use Aluminum with Steel Inserts at the Hub Axle & Since the NuVinci Freewheels internally, I will be using a track Cog on the Hub, the pedal chain will be on a second complete chain just outboard and will be using a Freewheel at the NuVinci hub in the rear wheel.)
