Tires Tested -- Flat and Rolling resistance statistics
morph999
I found this on another forum. After seeing this, I don't think I'd buy maxxis high rollers. It looks like Schwalbe makes better over all tires. Below, is the results of a study done by a german magazine.
RR (rolling ressitance): lower the number the better
Flat height: higher the number, the better
Thorn : A is the best score.... F is the worst score
(the below was written by someone else...not me...)
puncture height is flattening height:
the higher the number, the better.
they test it with a hetchet which falls down from test to test which higher and higher height., for example test 1 40cm, test 2 45cm, test 50 et cetera. the shown value is the first height the tire flattens.
they test also for thorn proofness with a metal thorn. i will edit that soon too. thorn test isnt available for all tires.
class a is highest resistance, class f lowest.
the fields of use:
cc is cross country race
am is all mountain
en is enduro
RR measurement:
(bad english incoming!)
Rolling resistance: All tires are set up with 2,5 bar. Then they are set up on the testing
role without load. Then they are accelerated on 20 kilometers per hour. Now the resistance
is set to zero to eliminate air resistance and bearing friction. Then the wheel gets loaded
with 50kg. After a short time the tire runs again with 20km/h. The difference from unloaded
and loaded run results gets the rolling resistance in watt.
movements in the carcass play a larger role than the tread.
mibro 2.25
rolling resistance: 22,3 watt
flattening height: 50cm
thorn: c
cornering stability/ability:5/6 (more= the better)
traction: 3/6 (more= the better)
2.35 nevegal
RR: more than 50watt
flattening height: 43,3cm
cornering stability/ability: 6/6 (more= the better)
traction: 6/6 (more= the better)
nobby nic 2.4 triple
RR: 28,0 watt
flattening height: 70cm
thorn: a
cornering stability/ability:6/6 (more= the better)
(update bike 4/08)
100% am
furious fred 2.0
RR: 19,9watt
flattening height: 42,5cm
thorn: e
cornering stability/ability:2/6 (more= the better)
traction: 2/6 (more= the better)
racing ralph 2.25 triple 2007
RR: 26,2 watt
flattening height: 65cm
traction: 4/6 (more= the better)
85% cc 15% am
racing ralph 2.25 evo TUBELESS 2008
RR: 19,8 watt
flattening height: 80cm
thorn: b
smart sam 2.1
RR: 28,9 watt
flattening height: 55cm
thorn: b
traction: 5/6 (more= the better)
100% cc
fat albert
RR: 34,4 watt
flattening height: 78cm
thorn: no information
little albert light (old test from 2004!)
RR: 32,1 watt
flattening height:-
thorn: -
big betty 2.4 triple
RR: 32,2 watt
flattening height: 110cm
thorn: c
(comment in the bike-test: big betty should have been rated 7/6 in traction and cornering stability)
15% am 85% ed
hutchinson python ng mrc medium 2.25
RR: 36,4watt
thorn: b
cornering stability/ability:4/6 (more= the better)
15% cc 85% am
hutchinson barracuda tubeless light
RR: 35,4watt
thorn: d
cornering stability/ability:3/6 (more= the better)
100% am
hutchinson toro 2.15
RR: 37,6watt
flattening height: 60cm
thorn: c
30% cc 70% am
hutchinson piranha mrc medium 2,3
RR: 40,8 watt
thorn: b
50% cc 50% am
larsen tt 2,3 exception
RR: 36,6 watt
flattening height: 85cm
thorn: c
50% cc 50% am
mountain king 2.4 protection
RR: 32,5 watt
puncture height: 65cm
thorn: d
50% am 50% en
speed king 2.1 supersonic
RR: 29,6 watt
puncture height: 40cm
thorn: e
90% cc 10% am
speed king 2.3 supersonic
RR: 27,9 watt
puncture height:50cm
thorn: e
10% cc 90% am
race king 2.2
RR: 23,9 watt
thorn: f
85% cc 15% am
diesel protection
RR: 43,5 watt
flattening height: 75cm
thorn: c
100% ed
explorer 2.1 supersonic
RR: 28,5 watt
flattening height: 40cm
thorn:c
100% cc
specialized the captain 2
RR: 39,2 watt
thorn: c
50% cc 50% am
specialized resolution 2.1
RR: 38,5 watt
thorn: d
25% cc 75% am
nokian nbx 2.3
RR: 26,8 watt
flattening height: 35cm
thorn: -
maxxis crossmark 2.1 exception
RR: 27,4 watt
thorn: b
100% cc
maxxis high roller 2.35 tubeless
RR: over 45 watt
thorn: a
100% ed
maxxis ignitor exception 2.1
RR: 34,3 watt
flattening height: 36,7cm
thorn: -
maxxis ignitor exception 2.35
RR: 32,3 watt
thorn: -
wtb mutano raptor (tested as all-mountain. maybe because of that only 2/6 cornering points)
RR: 30,7 watt
thorn: d
kenda karma 2.2
RR: 41,3 watt
thorn: e
80% am 20% ed
kenda small block eight 2,1
RR: 34,2 watt
thorn: c
IRC trailbear 2.25 (2004 tested, got the "bang for the buck" award! (costs about 10€ here in germany)
RR: 32,5 watt
flattening height: 41,67cm
thorn: -
vredestein tiger claw 2,1
RR: 26,2 watt
flattening height: 67,5cm
thorn: c
45% cc 55% am
CC-Race:
maxxis monorail exception 2.1
RR: 26,3 watt
thorn: b
100% cc
ritchey zmax intuition 2.0 wcs
RR: 38,2 watt
flattening height: 45cm
thorn:d
100% cc
schwalbe rocket ron 2,25 (stats: 436g weight, available in 2.1" and 2.4" and 2.1"/2.25" tubeless)
RR: 24,7 watt
flattening height: 52,5cm
thorn: c
traction:5/6 (more= the better)
85% cc, 15% am
wtb wolverine 2.2
RR: 25,9 watt
thorn: d
95% cc, 5% am
all mountain tires
continental rubber queen 2.2"
RR: 29,8 watt
thorn: c
85% am, 15% ed
ritchey zmax premonition 2.25 wcs
RR: 35,2 watt
thorn: f
100% am
specialized purgatory 2.2 s-works 2bliss
RR: 37,2 watt
thorn: d
85% am, 15% ed
enduro tires
continental rubber queen 2.4"
RR: 42,7 watt
thorn: d
100% ed
maxxis ardent 2.4" 60a folding
RR: 36,3 watt
thorn: c
15% am, 85% ed
schwalbe fat albert 2.4" front and rear
RR: 29,9 watt
flattening height: 83,75cm
thorn: b
45% am, 55% ed
That's great info.
Did they do a study on street tires?
Very interesting Morph, thanks! BTW, these all appear to be MTB-type tires?
They have also tests from 2006 for touring and race tires as a pdf linked from the bottom of this page (German language, but not hard to figure out the content from the format):
Test: Reifen 06/06 (6/2006) 7 Seiten | 0.7 MB | Kostenlos
http://www.bike-magazin.de/?p=270
Lock
