minde28383
- Joined
- Apr 2, 2010
- Messages
- 702
It is new for me. After Sabvoton closed I knew nothing. At least manufacturer has a name and website. Hopefully some support too.
hias9 said:I am running a SVMC072150 together with a 22S Lipo battery.
I use a second throttle for regen braking. Unfortunately it only starts working when the battery is already down to around 40% (83V).
The Sabvoton shows over 2V higher battery voltage in its software than real battery voltage.
It seems than the Regen voltage limit is somehow connected to parameter "over volt".
I cannot set "over volt" to more than 96V. Does anybody have a firmware on his controller that allows to set "over volt" higher than 96V?
Did anybody try to modify to controller so it shows correct/less voltage?
leffex said:In summary I ask
What is the output signal from a hall wire?
What numbers of wires do I need as a minimum and how do I connect this/these wires to only get that signal?
I was thinking to use this wire and put it as a phase sensor wire to another controller(controller2) that I use with a display and that controller2 needs input signal for hall so I can se actual speed.cycborg said:leffex said:In summary I ask
You may have figured this out, but here's my two cents. On my Sabvoton, for any connector that has a black wire (throttle, halls, comms, reverse, etc.), the black wire is connected internally to B-. So presumably the connectors with only one wire (hall meter, brake H, E-lock) are also referenced to B-.
I don't know exactly what the "hall meter" wire is. I would have assumed it's just connected internally to one of the phases of the hall connector, but this isn't the case. However, most likely it is referenced to B- and it pulses either once per motor pole pair or once per wheel revolution. So to use it as a speed reference, you would take the frequency of this signal and divide by the pole pairs of your motor (or not) to get RPM.
minde28383 said:I too have delay getting reply from QS regarding my broken controller.
I'm trying to reach them through their created chat dedicated to solve my issue in ''wechat'' app but no response from them for few days already.
My Sabvoton 72150 controller issue:
controller RED LED always ON
Bluetooth connection not working
PC app connection not working
All fets, capts, etc - OK
I suspect logic error / chip error
